How do you secure a wireless router
Click here for a link to the instruction manual. All this was retrieved from p.48
First off make sure your wireless connection is working
1. On the Setup tab of the Router’s web-based utility, click the Enable radio button next to WEP. Then click the Edit WEP Settings button.
2. You will see the 2.4GHz, 54g, Wireless-G (WEP) screen (Figure C-1). Next to Default Transmit Key, select which WEP key (1-4) will be used when the
Router sends data. Make sure the receiving device is using the same key.
3. For the WEP Encryption drop-down box, select the level of WEP encryption you wish to use, 64-bit 10 hex digits or 128-bit 26 hex digits. Higher encryption levels offer higher levels of security, but due to the complexity
of the encryption, they may decrease network performance.
4. Instead of manually entering WEP keys, you can enter a Passphrase in the Passphrase field. This Passphrase is used to generate one or more WEP keys. It is case-sensitive and should not be longer than 16 alphanumeric characters. (This Passphrase function is compatible with Linksys wireless
products only. If you want to communicate with non-Linksys wireless products, enter the WEP key manually on the non-Linksys wireless products.)
After you enter the Passphrase, click the Generate button to create WEP keys.
Note: All Wireless-G and 802.11b devices in your network must use the same Passphrase or WEP key.
5. WEP keys enable you to create an encryption scheme for wireless LAN transmissions. If you are not using a Passphrase, then manually enter a set of values in each Key field. (Do not leave a key field blank, and do not enter all zeroes. These are not valid key values.) If you are using 64-bit WEP encryption, then the key must be exactly 10 hexadecimal characters in length. If you are using 128-bit WEP encryption, then the key must be exactly 26 hexadecimal characters in length. Valid hexadecimal characters are “0”-“9” and “A”-“F”.
6. Check all the values, and click theApply button to save your WEP settings and return to the Setup screen. To cancel any changes you’ve entered on this page, click the Cancel button. To get more information about the features, click the Help button.
SOURCE: network security
Once you've logged into the router (open your browser, and type ONLY this into the Address line, without the quotes: "192.168.2.1). You should get a log in pop-up, "admin" is the username, and the password is left blank (or is sometimes "password"), again without the quotes.
Once logged in, you have a series of menus on the left hand side, Usually large blue lines demark each section, i.e. "Lan Setup", "Internet WAN", and of course the section you are looking for "Wireless". Under each header is listed each of the pages available for that function. For example, under Wireless you'd want the first 2 items: "Channel and SSID" - this is where you set the name of the wireless network; and "Security", which is where you setup whichever one of the Encryption options you want. This Encryption key is the password you will use when connecting wirelessly to the router from a PC.
Hopefully that is enough to get you setup.
SOURCE: security of wireless network
I NEED THE STEPS ON HOW TO SET UP SECURITY ON MY BELKIN WIRELESS ROUTER.
SOURCE: i need to password secure my belkin wireless router
This is not a difficult task, but if it is done incorrectly, your router will need to be reset. So, let's go ahead and get a long, thin pin, or sewing needle,or something that will reach into the recessed reset button hole, because we may need it a few times.
I too have a belkin wireless router, so I know a little about them. However, I dont know your exact model or firmware/software programming, so a true "step by step" is not possible from me. Contact Belkin for operator assistance. Here are some General things you will need to do.
1. Reset the router. Go ahead and do that now. that way, we have a clean slate. Press the reset button and allow the router to restart.
2. Make sure the Modem is connected to the INTERNET port on the router. You should see 5 ports on the router, 1 2 3 4 are ONLY FOR COMPUTERS. if it has a number do not put anything on it unless its a computer, or xbox or playstation game console. The MODEM, the DSL, or w/e will NEVER go to ports 1 2 3 or 4. Now, make sure that your MAIN computer is HARD WIRED to PORT 1 on the router. You DO NOT EVER make wireless router adjustments over a wireless connection. You must hard wire to the router.
3. LOG IN to the router. The router has a built in website that allows you to operate it. on a belkin router, that website is located at the Default Gateway address. (ok, you probably dont know what that means, but thats ok, we can still do this). MOST belkins have a default gateway address of 192.168.2.1. So, you will open your internet explorer and go to the ADDRESS BAR. There, you will type http://192.168.2.1 and press GO. You SHOULD see a page that says Belkin.
4. BY DEFAULT there is no username or password. so if you are asked to login, leave them blank and hit submit.
5. this is where it can get hairy, but, its nothing the reset button cannot fix. You will be looking for a few things First thing to do is click login, of course, so you can log in. remember, its default, so its blank.
6. Now that youre logged in, look for WIRELESS and click there. If you are using wireless machines, make sure wireless is ENABLED. It should be, by default, but, lets take a look and make sure, just to be safe.
7. Next, were gonna set the SSID to your last name, (or your dogs name or your nickname or favorite place). The SSID is default to Belkin, but if 10 ppl around you ALL have belkin routers, you'd have no way of knowing which one is yours, So, the SSID boradcasts a unique name to identify YOUR network. Changing the word Belkin to "Scoobydoo" would mean that you would be the Scoobydoo network, and anytime anyone is in range of your router, they would see "scoobydoo" as a site. You also want to ENABLE Essid broadcast, and unless you have an older wireless B card, set to Wireless G only. (g is more secure). Everything else, leave at the current setting.
8. Now we are going to SECURE your wireless so that when people see "scoobydoo" they wont be able to JOIN it, unless they have your KEY. Click Security. We are going to create a key. With Wireless G you can use a 26 character key, which is a set of HEXIDECIMAL characters. HEX is 0-9 and A-F. No letter higher than F will occur in Hex. So, click WEP (wpa is usually more secure, but I prefer WEP). Choose WEP and Choose 128 bit encryption. Next, use a passphrase, (this will generate a key for you). Say you put "shaggy" as the passphrase. Based on that word, a 26 character key would be generated. Now, This is important, WRITE THAT KEY DOWN EXACTLY AS ITS SHOWN. Without that key, no one can access your router on wireless. Also, dont forget to press "Apply Changes". Once you apply those changes, all your wireless connections will be lost. You will now have to go to each wireless computer, and apply the key to each one so they can access the router.
SOURCE: does not save wireless security settings
Encrypting the network blocks any unauthorized computer from accessing
the network and using its broadband connection. To enable WEP on the
router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2.
When prompted for a username and password type “admin” on password,
unless you have previously changed the password of the router, and hit
OK. This will bring you to the Setup page of the router.
3.
Depending on the firmware of the router. Click on the WEP Key Settings
button. Or you can click the Wireless tab and select Wireless Security.
Or you can click the Security Tab and select Wireless.
4. From the
WEP/Security Settings window, you may enable 64 or 128 bit WEP then
enter your Password on the Passphrase field and click on Generate. Make
sure to copy the characters on Key 1-4 on a piece of paper before you
hit APPLY. You will be needing this once you enable WEP on the wireless
PC’s. Also take note that if you enable 64 or 128 bit on the router,
this should be the same WEP level that you will enable on the wireless
cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1.
Go to start>Control Panel>Network Connections>Right click on
the Wireless connection then click on Properties>Click on the
Wireless Networks Tab
2. From the Wireless Network Connection
properties window, under the Preferred network click on Add then type
your SSID on the SSID field and check the box for Data Encryption then
then uncheck “The Key is provided for me Automatically”
3. Type
your WEP Keys on both the Network Key and Confirm Network Key field.
(This set of characters should be identical to the WEP Keys Settings on
the router. For 64-bit WEP you should have 10 characters, for 128-bit
you should type in 26 characters.) Then hit OK and then OK again.
4.
After hitting OK a pop-up should appear on the lower right hand side
saying “Connected”. Try pointing your mouse arrow on the lower double
monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make
sure that the WLAN utility of the Linksys adapter is already is
installed. If not, you may follow follow the procedures below for
"Installing the Linksys WLAN Utility"
1. Click on Start then
Programs, then click on anything that says something about the Linksys
Wireless Adapter. On the menu, select either WLAN Utility or Wireless
Configuration Utility
2. On the lower right-hand side of your
screen, double click on the Linksys Icon. This will bring up the WLAN
Configuration Utility.
3. Click on the Profiles Tab. Make sure that
the SSID that is set to default is your routers SSID. Highlight Default
then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6.
Type your WEP Keys. This set of characters should be identical to the
WEP Keys Settings on the router. For 64-bit WEP you should have 10
characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
SOURCE: how can i secure a BELKIN WIRELESS G ROUTER
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
--After logging in. In the main menu on the left, click on Wireless
Settings, from there you can check the wireless security or you can setup wireless security from there
if you haven't done so.
Hope this helps. Have a nice day. Don't forget to vote if you find this guide helpful. Thanks.
i want do put my modem in security when i am surfing in net and the others can not share with me the same acces point this put in interogation
