Question about eMachines E19T6W 19" Monitor
My E19T6W 19" LCD monitor
Sorry, I have no solution, just thought you might like to know that I am having the exact same problem.
The only thing I can add is that it appeared after a night that my computer was set to do a weekly upload of Microsoft, anti-virus and anti-spyware updates. Also, that night we had some electrical storms. The menu pops up in the bottom right corner at very erratic intervals and sometimes just flashes, while other times stays on for minutes. It is driving me crazy!
I have tried updating the monitor driver and the video card using the "Device Manager" icon found in the "Control Panel". No luck. I have also ran anti-virus and anti-spyware scans and also used AVG to scan and fix registry errors. No luck.
I am open to suggestions.
Thanks
Posted on Mar 29, 2011
Main menu on the lower right hand side keeps popping up
Sounds like your menu button on the monitor is stuck in the pushed in position. See if that is the problem and use a needle, q-tip with alcohol to pop it back out.
Jan 27, 2013 | Gateway FPD1975W 19" LCD Monitor
Power is on but no display on screen emachine e19t6w hd monitor
If the power indicator is on and nothing is showing, you probably have had a power supply failure
Jan 04, 2013 | eMachines E19T6W 19" Monitor
Monitors
What is happening if you remove it and the unit connected to it from power and then power back?
This is a monitor and have you tried it on another unit?
Dec 06, 2012 | eMachines E19T6W 19" Widescreen LCD...
Everything is zoomed in
My E19T6W 19" LCD monitor has a menu that keeps popping up on the bottom right corner of
my screen. Has been doing this continually since I got it. Changes from the eMachine monitor tour to resolution and contrast menus. I keep turning it off and within seconds it'll be right back. For the most part I just ignore it, but recently it has been driving me insane during movies.
Aug 29, 2011 | eMachines E19T6W 19" Monitor
I went from a 17" screen to a 19" screen. Now all my desktop icons have shifted to the left? How do I recenter them on the desktop?
It's pretty easy. Start by selecting all icons at once. Just start in the upper left corner, click & hold the mouse button and go to the lower right corner and they will all be selected. Then click and hold one of the icons and drag them to the center of the screen and let go. If they snap right back you will first have to right click on a part of the screen without an icon and a menu will pop up. Go to the view menu and click on "Auto Arrange" to take off the check-mark.
Jul 03, 2010 | ViewSonic VX910 19" LCD Monitor
Monitor's display is shifted up and right so that there is just black space to the left and all along the bottom whereby cutting off the display. cannot see bottom menu bar.
One of the buttons on the front of you monitor (bottom right hand corner of the bezel) is a menu button. Press that then using the the arrows up and down buttons go the the horizontal and vertical positioning option. Once chosen move the display as desired.
You could also press the Auto (config) button, that may do the same for you.
May 17, 2010 | Acer AL1912 19" LCD Monitor
Language menu popup on E19T6W monitor
That's a manufacturing issue in that model of monitor. You have to live with it.
Dec 04, 2009 | Office Equipment & Supplies
Main menu inviting to take a tour on how to adjust the monitor keeps popping up uninvited.
Your screen settings are not optimized for that monitor, most Gateways (to h*&%) come with a drivers disks for the monitors put that in and run setup for the monitor.
May 02, 2009 | Computers & Internet
Config screen keeps popping up
A friend of mine had the exact same same problem. I think I fixed it, because it has been 2 hours, without the menu popping up. You need to open the monitor:
- Place it face-down on a flat surface
- Remove the cover of the hinge by gripping it with both hands and gently squeezing and pulling.
- Undo the 4 screws and remove the stand (base)
- Undo the four screws tha hold the cover down (4 corners)
- Use a flat screwdriver to seperate the 2 halves (I used 2, a small one to lift the back, a bigger one for leverage)
You will see a small PCB, fastened by 3 screws, at the bottom (where your menu+on/off buttons are) with a ribbon connection to the screen. Next:
- Unscrew the PCB, and gently lift it out.
- Clean the microswitches and the ribbon cable connection.
- Reassemble the monitor.
To clean microswitches and the connection, I used Kontakt Video 90 spray. There must be sprays on the market where you are. It's basically an alcohol-based cleaning spray. Good for cleaning video/tape/floppy heads, CD/DVD lenses, memory modules, etc.
Dec 07, 2008 | Acer AL1912 19" LCD Monitor
eMachines E19T6W 19" Monitor Logo
733 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
