Question about GE JEB1095SB Oven
How do I change the clock time - GE JEB1095SB Oven
    Problem Solver:
  • 9 Answers
First set Hrs and then minutes.
Posted on Nov 07, 2010
I have a Dacor ERD48SCH/NG oven/range. Accidentally changed the clock time to military (24-hour) time, and now can't figure out how to change it back. How do I change back to regular 12-hr time?
Step 1 Locate the "Clock" button on the display. The display is located above the oven door. It clearly shows the time and has settings for temperature, time and cooking.
Step 2 Press and hold the "Clock" button until the time starts to blink.
Step 3 Set the time with the number pad. Ignore the colons and enter the number straight through. For example, if the current time is 10:08, just type 1-0-0-8.
Step 4 Set AM and PM by pressing the "#" button. Press "Start" to finish.
Jul 07, 2018 | Dacor Ovens
How do adjust the clock to daylight saving?
Touch TIME then the display will begin flashing timer
Use rotary knob to change this to CLOCK
Touch TIME again and it will say ENTER TIME with the time flashing
Use the rotary knob to change the time as required
Touch START and the time is now changed
Page 12 if you need it
Bosch HBL745AUC Use and Care Manual
Oct 07, 2014 | Bosch HBL 745 Stainless Steel Electric...
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Regards,
BElectric
Dec 31, 2010 | Bosch Ovens
How to work oven and clock
There should be a clock button or a picure of a clock. It will flash when you press it indidcating you can now change the time. Change the time but entering the time or pressing an arrow up or down until you get the time desired.
Aug 17, 2010 | Ovens
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Reset clock - how do I do it?
Push and hold clock botton, until display changes, then use the scroll controls to change numbers, then when the time it's correct, press clock again to enter settings
Dec 23, 2009 | Candy Ovens
Changing the clock time
If you mean simply adjusting the 12 hour LED to the time of day...Push the area on the glass control panel printed "clock". Enter time of day by using same "buttons" you use to adjust oven temps, as in 1-2-0-5, which would be 12:05. then push clock once more. If you meant changing from 12 hour time to 24 hour time, that is complicated, takes two people, and is on page 30 of your owner's manual.
Jan 23, 2009 | Thermador SC302T Electric Double Oven
Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Nov 17, 2008 | Ovens
Ovens Logo
32 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
