Question about HP LaserJet 3055 All-In-One Printer
It is giving the 50 fuser error, but the fuser is good,
  • 132 Answers
Fuser chip failure. Change the chip only.
Posted on Nov 07, 2010
HP 4V error 50, replkaced fuser and power supply. Any ideas?
Check the fuser connectors for bent pins.
Possibly bad fuser cable assembly.
Make sure printer is powered off for 30 minutes before powering on.
Gives capacitors a chance to drain.
Jun 27, 2011 | HP LaserJet 4v Printer
Hp laser jet 2420 printer 50. error
This is an error with your fuser...you need another fuser...any 50.x error is related to that and they are something that needs replacing regularly(100-150k pages) the heat resister goes out or the film tears..ect....Try www.getthatpart.com for a good deal on a used one...Used are normally just as good as new for a lot less and these guys guarantee their units, they have someone you can call on the phone, so I recommend them. Hope this helps you.
Oct 25, 2010 | HP LaserJet 2420dn Printer
I can't print anything, and it says 50 service
This is a fuser error. It means the the fusing unit is not heating up properly. This is the unit that gets hot and fixes the toner onto the paper just before the paper exits the machine. Easy to swap out if you can find a fuser unit.
Good Luck
Nov 22, 2009 | HP LaserJet 4 plus Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
Error code- 50 service
Hi Sheila,
The following page gives the reason http://www.all-laser.com/cgi-bin/webc.cgi/error50.html
Seems the printer needs something called a fuser. There is a link to maintenance packs including the fuser or just the fuser alone.
Apr 27, 2009 | HP Office Equipment & Supplies
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
Error 50
Error 50 is a fuser unit fault code. You can take apart the fuser unit and see if the fuser lamp is functional. Also check some of the other thermal parts on the fuser. If everything checks out, you will probably have to replace the thermistor. You will need to see if it will be cost effective to replace the necessary parts (Brother parts are not cheap), or to buy a new printer. Hope this helps. Good luck.
Jun 19, 2007 | Brother HL 1430 Laser Printer
HP LaserJet 3055 All-In-One Printer Logo
174 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
