Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Heater will not light, i have followed the instructions ,turning thermostate all the way up first,and turn on now what happenes is the glow plug or igniter gets red hot the blower kicks on fuel sprays on it for about 5 seconds but will not lite then it shuts off,the fuel is diesel clean and fresh,spray nozzel works great to nice funnel out spray,would just like to know what could be the problem as to why it will not light, thank you.
  • 232 Answers
If you brought the heater to our shop, and gave the above description, the first thing that we would do is check the air pump pressure.
Then, if the pressure is correct (not just close) we would check the photocell for signs of insect nest or something similar blocking the view of the eye.
You must troubleshoot to find out if the problem is fuel related or electronics related- maybe these tips will help (click for link).
Posted on Nov 07, 2010
My heater is on the heat light continues to flash and nothing happens
when you turn it on does the ignitor glow if not check fuses and ignitor if ignitor glows does the gas valve open if so is gas on? if not need more info
Sep 09, 2014 | Pool & Spa
Occasional Starting Problems
my guess it does this only cold block. right. a key fact.
glow plugs failing
just because a lamp come on , dont mean much,
actual glow plug current is what matters. (proper)
only takes 3 things
proper compression.
glow plugs
fuel.
Apr 06, 2014 | 2000 Suzuki Grand Vitara
Heater will not light when turned on.
depending on your ignition sorce pilot light or glow plug check for cracks or chips. if you have a glow plug do not touch with your hands. oil from hands will cause them to burn out.
Jan 15, 2014 | Dayton (3E461) InfraRed Heater
Hi, I need a users manual for a Robeson Kerosene space heater model # 03-2619-91. I tried to light it with an open flame and nothing is happening. Thanks
DO not try to light with flame. Check fuel an vac lines first.then ck glow plug. to ck plug, remove leave power connected.to plug. ground plug to unit. Turn on switch.plug should glow bright red.
Jan 01, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
The electronic ignition on a gas water heater will not heat up and glow red to ignite the gas to heat the water atwood r/v water heater
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Jul 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
My glow plug light does't always come on first time I turn the key on my 2004 Accord diesel, when this happens the car just turns over and won't start. If I wiggle the key a few times the light comes on...
hi, there maybe problem with the ignition, the heater trigger on the ignition may be a little loose thats why you have to shake it and comes to contact on a certain time. check the heater relays too for it maybe faulty already. hope this helps
Feb 19, 2010 | 2004 Honda Accord
Heater plugs for nissan terrano 2
i have a nissan terrano 2.7 dti heater light not coming on some times dose and some times does'nt and it wont start
Oct 06, 2009 | 2002 Nissan Pathfinder
Not getting any fire
Can you give us a make and model number?
Nov 11, 2007 | Heating & Cooling
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
804 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
