Question about DistinctDev Speedometer
How to replace the speedometer sensor on a 1996 jetta trek
98 jetta error code p0101
Can be loose speedo wiring connectors under instrument panel or its issue with speed sensor on transmission.
I suggest you to go through help links mentioned below with appropriate solutions to confirm the problem :------
How to trouble shoot speedometer?
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
1996 fiat bravo speedometer not working?
http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working?
http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html
Speedometer runs backward?
http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html
Warning lights on and speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.ht
Speedometer not working on 1993 Ford F350?
http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Vehicles Cluster panel Not reading Miles?
http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html
Odometer works properly but speedometer works intermittently?
http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
These will help.
Thanks.
Nov 27, 2012 | 2008 Volkswagen Jetta Wagon
Where do you put antifreeze in a 1996 volkswagen jetta?
As with most cars you fill it up, at your radiator, but for your Jetta their is a reservoir, just make sure you fill it up to the proper levels, the reservoir is round and in the back, and right side of engine compartment, it is for my 96 Jetta Trek.
Sep 02, 2010 | 1996 Volkswagen Jetta
I need a firing diagram for a 1996 volkswagen jetta trek 2.0
from the front of the engine looking back to the gearbox the firing order is 1342. and the ht leads are all different lengths to fit the distance from front to back.
Aug 24, 2010 | 1996 Volkswagen Jetta
Need to replace the water pump on my 96 vw jetta trek
alot of theses cars use the water pump as part of the timing and if you install it wrong you will have issues. go to mitchll1diy online and read up on the procedures. for 10 bucks its your safest bet.
Jul 31, 2010 | 1996 Volkswagen Jetta
1996 Jetta TREK turn signals dont work need diagram of relays and fuses. Thanks
I just used this for my 1999 Mk III Jetta 2.0L.
http://www.urofixx.com/forums/index.php?s=97f3151362f9053badf1c3ac9946baec&showtopic=78757
Hope it helps.
Jul 24, 2010 | 1996 Volkswagen Jetta
1996 VW Jetta 4.0 cyl Gauges are going out/Dashlights...
I have the same problem, I own a 1996 VW Jetta Trek Edition,
I suspect the dashboard instrument panel is going out,
or it is the wire harness.
Everytime I hit a bump on the road one of the gauges acts up.
So I am going to replace my whole dashboard instrument panel
and see what happens, if that doesn't work, then it must be the harness
Aug 23, 2009 | 1996 Volkswagen Jetta
I have a 1996 VW Jetta, odomoter and speedometer
Either you have a broken wire some where from the speed sensor to the cluster or you have connector at fault, the one which hookup the dash cluster to the main wire bundel. Check the connector, maybe a pushed back pin !!
Aug 08, 2009 | 1996 Volkswagen Jetta
Se calienta mi jetta 96 trek tiene encendido el testigo de temperatura
mira si se te calienta rapido cuando lo manejas es tu bomba del agua cuidado puedes danar el motor.si toma mas tiempo en calentarse esos carros tienen sensores que se danan i causan eso tambien
Jul 12, 2009 | 1996 Volkswagen Jetta
1996 Jetta Treck - overheating
thermostat replace temp sensor its cheap i hope your water pump is not bad you could mess engine up if you keep on running car and is overheating.
May 16, 2009 | 1996 Volkswagen Jetta
1996 VW Jetta Trek Radio won't work
I have this same issue, it is not code related, I have a code and the radio works just fine WHEN THE CAR IS OFF. As soon as the engine starts, the radio loses power, did you ever find a solution to this?
Apr 25, 2009 | 1996 Volkswagen Jetta
DistinctDev Speedometer Logo
120 people viewed this question
Top DistinctDev Apps Experts
Erin Wood
Erin Wood
Are you a DistinctDev App Expert? Answer questions, earn points and help others
