Question about GE DRSR483ED Electric Dryer
Ge driver 10 years old dryer squeaks and if i manually spin drum squeaks what should i do
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Nov 11, 2010
Troubleshooting a problem with high pitched squeaking in GE dryer model PBVH520EJ0WW Squeaks when load is small or nearly dry - repairman came to check it out and said he 'couldn't fi
Could be the bearings going, other possibilities could be that the drum is slightly misaligned and scraping against the housing, although that's not very likely, or a bad belt.
Although sometimes it's some obscure thing, I could be compleatly wrong.
Oct 01, 2014 | Dryers
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Jan 25, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
WE3M26.
Sep 17, 2008 | GE Profile DPSR473EW Dryer
My dryer is squeaking on the dryer spin cycle.
What is your model number ...sounds like the drum glides are going out or the support rollers
Jul 31, 2008 | Dryers
Squeak
It is proably the center bearing in the back of the drum, especially if it at least a few years old. It can be replaced by you if you are very handy.
Dec 22, 2007 | GE DBL333EA Electric Dryer
GE DRSR483ED Electric Dryer Logo
202 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
