The dryer should not be pushed all the way against the wall. For the ventilation to properly work, you should leave about a one foot space between the back of the dryer and the wall. Using 90 degree elbows on the dryer and wall can also eliminate crimping. Also, it is strongly recommended that use use the semi-rigid metal type vent hose ducting. It is not that expensive and comes in adjustable lengths. The semi-rigid ducting is recommended by most builders and it resists crimping and rodent damage. If you continue to use a dryer with the exhaust vent clogged it will lead to eventual heating circuit failure due to overheating. If you have any questions, please post back and let me know. I hope this helps answer some of your questions.
NOTE: If you purchase semi-rigid ducting, make sure you purchased the hose clamps that go with it. This will prevent the hose from slipping off the connection points.
