Question about LG LFC23760SW Side by Side Bottom Freezer French Door Refrigerator
How to remove the fuse? - LG LFC23760SW Side by Side Bottom Freezer French Door Refrigerator
    Problem Solver:
  • 9 Answers
Call the Co. Service Engineer.
Posted on Nov 07, 2010
How do I change the fuses?
Remove the fuse box cover remove old place new fuse of same size. Step by Step:
  1. Locate your car's fuse panel.
  2. Take off the fuse panel's cover.
  3. Locate the blown fuse.
  4. Remove the broken fuse.
  5. Insert a replacement fuse of the correct amperage-make note of the fuse panel and your owner's manual on this one.
  6. You do keep a few extra fuses of various amperage in your glove box.
How to Find and Replace Blown Fuse in Your Car or Truck
Changing Fuse DMV org
How to Change Vehicle Fuses
How to Change Car Fuse in 8 Easy Steps
May 30, 2016 | Cars & Trucks
How to remove the steering wheel for replacement
SIR DISABLE:
DRIVER SIDE
Many service procedures require the air bag system to be disabled to prevent accidental deployment. The air bag system can maintain sufficient voltage to cause deployment for up to 2 minutes after the ignition switch is turned off, the battery ground cable is disconnected or the DERM fuse is removed. If the inflator module is disconnected from the deployment loop by the following procedure, service can begin immediately without waiting for the 2 minute time period to elapse.
  1. Turn steering wheel so that vehicle wheels are pointed straight ahead.
  2. Turn ignition switch to Lock position and remove key.
  3. Remove air bag fuse from fuse block.
  4. Remove steering column filler panel.
  5. Remove Connector Position Assurance (CPA) and disconnect yellow two-way connector at base of steering column, Fig. 1.
PASSENGER SIDE
  1. Remove air bag fuse from fuse block.
SIR ENABLE:
Driver Side
  1. Turn ignition switch to LOCK and remove key.
  2. Connect yellow two-way connector and install connector position assurance (CPA).
  3. Install steering column filler panel.
  4. Insert air bag fuse into fuse block.
  5. Turn ignition switch to RUN and verify that the air bag warning lamp flashes seven times then turns off.
Passenger Side
  2. Insert air bag fuse into fuse block.
  3. Turn ignition switch to RUN and verify that the air bag warning lamp flashes seven times then turns off.
Apr 10, 2015 | 1996 Chevrolet K1500
1991 Infiniti M30 Fuse
most just pop out.. replacement is reverse of removal
Jan 07, 2014 | 1991 Infiniti M30 Fuse
How to remove glow plug fuse from holder
there are two 10mm nuts securing the fuse box, remove those and then push the 80amp fuse downwards out of the fuse box (you'll see a clip to the side of the 80amp fuse) once you've slid it out from the bottom of the fuse box you'll see it the wire terminals bolted to the fuse. undo the 10mm nuts and remove. easy as!
Aug 04, 2012 | 1989 Toyota 4Runner
The fuse panel for the power windows is hard to get to any easy way to get to it
Remove the fuse with the fuse puller stored in the fuse box, pulling the fuse straight out. If the fuse puller is missing, needle nose pliers can easily grip the fuse to pull it out of the socket. Hold the fuse up to the light to see if the metal strip is broken from one end of the fuse to the other. If it is broken, the fuse needs to be replace
sincerely. God bless you
ernesto cuaddramanagua,nicaragua.c. a
Feb 15, 2012 | 2002 Ford Taurus
THERMAL FUSE replacement
hi,
You will need to remove the back to get at the lamp housing from the inside to see it, its a bit tricky as it involves removing some pieces to get at the fuse and maybe just lifting the light engine assembly.
To access the tremal fuse you hve to remove the following item.
1. Remove rear cover
2. Remove Sub-woofer speaker box (not needed for A20 models)
3. Remove metal backing plate.
4. Remove Exhaust fan
5. Remove Optical Block screws
6. Remove Open thermal fuse.
7. Install new Thermal Fuse
I have added a video wich will help you access the tremal fuse. Its a different model may be help you.
Also added picture of connector which gose to the thermal fuse.
ajin_g_69.jpg Ok
Aug 26, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
How do I remove the fuse box to replace the ALT Fuse? I removed the lower half of the fuse box, but can't seem to get the top half removed.
FUSE LINK LOOKS LIKE A FUSE.JUST USE FUSE PULLER OR PAIR OF SMALL NEEDLE NOSE PLIERS TO REMOVE FUSE OR FUSE LINK TO ALTERNATOR..BESURE THE BATTERY NEGATIVE CABLE IS DISCONNECTED FIRST TO KEEP SHORTING OUT OTHER FUSE LINKS AND FUSES IN THE CIRCUIT.TURN OFF RADIO FIRST BEFORE REMOVING NEGATIVE BATTERY CABLE
May 08, 2011 | Lexus ES 330 Cars & Trucks
Heater has stopped working
(1) possible blown fuse.
Note that fuses blow for a reason - seek out the reason, or it will blow its new fuse too.
The main fuse block is located inside the left side of the engine compartment near the battery. There is also an interior fuse panel located just above the left side kick panel.
Interior Fuse Panel
The interior fuses simply unplug from the fuse panel. Use the fuse puller tool provided with your car to remove fuses from the panel. The tool is located on the back of the interior fuse panel cover.
(2) possible blower motor dead. See maintenance manual excerpt below.
(3) possible blower motor relay faulty. Location of Blower relay:
Under hood, drivers side, front engine area,rear of headlight housing; relay mounted on drivers side of radiator shroud.
1990-92 Mazda 626 and MX-6
See Figure below
  1. Disconnect the negative battery cable.
  2. Remove the glove box and the underdash cover.
  3. Detach the electrical connectors from the blower unit.
  4. Remove the blower unit-to-fire wall attaching bolts and remove the blower unit assembly.
  5. Remove the blower motor fan-to-motor fastener.
  6. Remove the blower motor-to-unit attaching bolts, then remove the motor.
  7. Installation is the reverse of the removal procedure.
Feb 01, 2011 | 1991 Mazda 626
Where are the fuses
Removal & Installation Use the provided plastic fuse puller located in the fuse panel to remove fuses. The lid of the fuse panel has a diagram of the fuse locations and amperage ratings for each circuit. The fuse is removed by simply pulling upward on the fuse with the removal tool.
The fuses are easily checked by visual inspection. With the ignition switch OFF, pull the fuse out of the holder. Check the fuse filament. It should be continuous and not broken. If the filament is broken, replace the fuse with one of the same amperage rating.
Use a plastic prytool or if necessary a sturdy key can be inserted into the small slot in the cover. Carefully pry to cover off to remove—1.8L Passat shown
The cover is held in place by 3 retainers—1.8L Passat shown
Mar 07, 2010 | 1999 Volkswagen Passat
Can't find the heater blower fuse
The interior fuse panel can be found below the instrument panel and the exterior fuse panel beneath the hood, near the battery.
  1. Remove the fuse panel cover.
  2. Locate the fuse to be removed.
  3. If equipped with a small fuse removal tool (usually attached to the inside of the fuse panel cover), use the tool to grasp the fuse. Otherwise, you can use your fingers to pull the fuse from the panel. Remove the fuse and inspect it to see if the filament is blown.
  4. If the fuse is blown, replace it with a fuse of the same amperage rating.
  5. Replace the fuse removal tool, if applicable, then install the fuse panel cover.
  6. If the fuse continues to blow, check the circuit or component that the fuse is protecting, and repair it as necessary.
The interior fuse panel is located below the driver's side of the instrument panel
It is fuse number 15 and it is a 30 amp.
Oct 11, 2009 | 1994 Ford Escort
LG LFC23760SW Side by Side Bottom Freezer French Door Refrigerator Logo
111 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
