Question about Maytag Performa PAV2200
  • 487 Answers
Follow LINK
Posted on Jun 21, 2008
My stackable maytag lse7804ace washer will not drain after agitation. The dial sticks and begins to hum.
As with most appliances and cars wiring harness are made to service many models for economy to the manufacture. One harness may have 50 wires in it but your washer may only use 30 of those wires. A wiring diagram is a must. If it did not come in the paper work that came with the washer you should be able to find it online. The last 2 washes I worked on had away to put them into a self diagnostic mode this may also be in your manuel. In both cases they had a no drain problem as the code stated and gave me a place to start and because of the way washers are made now adays the drain water pump gets clogged after so many seconds of not pumping it will shut the washer down. I guess to keep the motor from burning out. Taking the water pump assembly apart I found a sock yes a sock wrap around the impellers and this was in both washers. Removed the socks reassemble and both washers worked like new. this site might help you too.
I have a Maytag refrigerator never again from day one one problem after another. The Maytag of yesterday is no more.
Jun 14, 2014 | Maytag Performa PAV2200
'need wiring diagram for door latch on maytag performa model#pav2300. I have the part. Retired industrial electrician.
Not sure if this will paste here if not enter your model # at the diagrams will come up on the right hand side.
May 03, 2010 | Maytag PAV2300 Top Load Washer
We're trying to attach the four prong cord back on to our Performa Dryer and we can't remember where to attach the green wire
The green(ground) wire attaches to the chasis(frame). Any frame screw within reach of the connection box is fine.
Nov 07, 2009 | Maytag Performa PAV2200
My maytag dryer won't heat up
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 17, 2009 | Maytag Performa PAV2200
Maytag performa dryer quit in the middle of a load
probably the thermal fuse i just fixed mine it did the same thing it was about twenty bucks for the kit and it is located right under the wires that feed the heating element
Dec 15, 2008 | Maytag Performa PAV2200
Installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
Apr 22, 2008 | Maytag Legacy Series Top Load Washer
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Jan 10, 2008 | Maytag Performa PAV2200
Maytag performa
Sounds like your motor brushes are very worn.(Its a bit like grinding metal when a cars brake pads are worn.)Should only cost 10 or so pounds for new ones,access to the motor will be required.Unplug washer b4 changing.
Aug 24, 2007 | Maytag Performa PAV2200
Washing Machines Logo
152 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
