Question about Maytag Neptune MDE5500AY Electric Dryer
HOW TO REMOVE LINT FROM INSIDE DRYER? - Maytag Neptune MDE5500AY Electric Dryer
    President:
  • 3,074 Answers
Remove the front panel, open dryer door, remove screws from hinges lift up and out, remove the other four screws on opposite side, lift front panel off, with a vacuum get all lint out, if need be disassemble the dryer futher, just remember to unplug dryer first. Hope this helped Tim
Posted on Nov 07, 2010
SOURCE: How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Posted on Feb 11, 2009
lpjok01
  • 6 Answers
SOURCE: The dryer is not heating as it should. I need to
Check out this link. It should provide you the assistance you're looking for.
Good Luck!
http://www.ehow.com/how_2074306_fix-dryer-lint-problems.html
Posted on Apr 23, 2009
iwillfixforu
  • 619 Answers
SOURCE: Lint has built up inside the 3 plastic fins of Whirlpool Duet
What is the model Number. Does your lint screen go thru the top or is it in the door.
Posted on Jan 31, 2010
Testimonial: "Great directions...solution was easy to follow and exactly what I needed!"
  • 122 Answers
SOURCE: How do I remove front panel so I can vacuum the
remove 4 philips head screws inside door opening. twist the top narrow part of the front panel to release itfrom clips, tip panel out towards you and lift off. there are 6 5/16 screws on the sides of the bulkhead that needto be removed(there are 8 but 2 of them can be left in). lift the top slightly and you can remove the front bulkhead and clean the duct area.
Posted on Dec 10, 2010
SOURCE: how to remove lower front panel on kenmore 90
On my 7 year old Series 90 Dryer, I
- unplug the dryer
- use a flash light to locate the two black metal spring clips (located about 3 inches from each end of the lower panel along its top edge). They can be seen in the crack between the upper and lower panels.
- use a putty knife, or similar tool, to press down each clip while pulling out that edge of the panel.
- The panel slips off the lower clips easily.
- on some models there is a lone yellow wire with a connector on the end. If it is unconnected to anything, don't go nuts thinking that you have disconnected a wire by accident. Its one of those unused wires on some models.
- collect as many coins as possible before you vacuum the inside of the machine. Leaning the machine forward can often slide hidden coins to the front. BE SURE YOU CAN LEAN THE MACHINE WITHOUT HAVING IT FALL ON YOU. Otherwise, plan on collecting the coins from the vacuum cleaner when you finish.
- replace the panel by first threading the panel on to the lower clips, then closing the panel. CLICK, CLICK. FINISHED.
Congrats you have cleaned it, possibly avoided a house fire and added to the mad money collection. Hope this helped.
Posted on Jan 13, 2011
How do I get into my whirlpool duet front loader dryer to clean the lint out
Hello. First, turn the power off to the dryer or remove the power cord from the AC outlet. Next, locate the 2 screws in-between the upper and lower front panels and at the bottom front of the dryer--there will be 2-3 screws, usually 1/4 inch hex head, and remove them--use a magnetic nut driver, it makes it a whole lot easier! (note:sometimes, to replace the panel, you have to push up on the bottom of the panel hard to get the screw holes to line up again.) Set the panel aside. Open the dryer door and remove the lint screen from the holder. Close the door. Next, notice the blower housing cover, pic 3, #45, lower left corner. There should be 3-4 screws holding the cover to the blower housing. Remove the screws and cover--use caution--most metal edges inside a dryer are unfinished and razor sharp--akin to putting your hand inside a box of razor blades(ask me how I know this, lol). Remove any lint build-up inside the cover with a vacuum. Again, using a vacuum, suck out any lint from inside the blower housing and fan as best you can. Take care to not damage the fan blades! Now, try to remove as much lint build-up as you can with the vacuum. Be especially careful when vacuuming around the mouth of the heater element. Do the best you can. At this point, re-assemble the dryer using the reverse of assembly. If there is still a lot of lint inside the cabinet and you can't reach it--STOP! In order to remove the remaining lint requires removal of the front bulkhead(large metal plate that supports the front of the drum), drum belt, and drum from the cabinet. This is INVOLVED and can be very difficult to re-assemble if you have never done it before. Call for service. I hope I helped you!
Oct 02, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
My electric dryer has heat but won't turn. How do I change the belt?
i'am guessing you have a top lint filter,remove it than remove the 2 screws,pull the top toward you and up,disconnect the door switch,remove the 2 inside screws,lift up and pull off,if this is not the top lint filter please let me know and i will tell you how to do the inside lint filter-mike
Feb 15, 2010 | Kenmore 62602 Electric Dryer
Dryer leaking water
lint is blocking the air from blowing outside and the steam has nowhere to go,you need to clean out your dryer and vent line,go outside and see if the flapper is blowing fully open,if there is a cage on outside vent remove it,if you have a long vent line from the wall to the outside blow it out with a leaf blower,if your lint filter is on top take the back panel off and remove the duct that the filter slides into,if the filter is inside the dryer,remove front panel and remove the duct and clean it out,also vac out the inside of dryer,if your vac has a blower on it blow the lint off the motor,you'll be surprised how much lint will come off the motor,you should do this once a year so you don't have a fire,usually the thermal fuse willpop when dryer gets that backed up
Dec 14, 2009 | Whirlpool Dryers
MY DRYER IS NOT RELEASING THE AIR OUTSIDE AND MY DRYER IS GETTING SUPPER HOT ON TOP
squished vent hose behind dryer, then clogged vent, then dirty lint filter, then lint built up inside dryer because of vent issue, after fixing vent issue, remove lint from inside blower area filter area etc.
Oct 25, 2009 | Whirlpool LER5636P Electric Dryer
Dryer has hot air but takes 2-3 hours to dry clothes. What can I do?
This is almost always due to lint build up in the vent pipe. pull the dryer out from the wall, disconnect the vent pipe. look inside the rear of the dryer and into the pipe. remove lint that is present. go out doors and examine the vent from that end. finally remove the lint catcher in the dryer and look in there. remove any lint you see.
Jun 22, 2009 | Dryers
It is taking 3 full cycles to dry my small loads on my Maytag Performa PYE2300AYW. I have cleaned lint tray and trap. I need to clean the lint from the inside of my dryer - How do I do this?
The main area that you have to clean is the pipe leading from the back of your dryer to outdoors. Pull your dryer away from the wall. Unplug it. Unfasten the vent pipe. Now look into the back of the dryer exhaust and remove any lint you see there then look into the vent pipe and remove any lint. Finally go outdoors and remove any lint you see in the pipe or the pipe grill/cover.
Jun 04, 2009 | Maytag PYE2300AY Electric Dryer
LG dlg5988W Gas Dryer - flashing "clean filter" light
i got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
Feb 20, 2009 | LG DLG5988 Gas Dryer
I own a whirlpool gold dryer about 4 years old. I empty the lint catcher frequently. I noticed however, that sand has accumulated inside the dryer, I hear the sound when the dryer starts tumbling. How...
not as hard as it will sound here we go
remove the lint filter
remove the 2 phillips screws at the filter housing top you will see these screws after you have pulled out the lint filter
unplug the dryer
remove the back panel
on the left side is the lint filter housing it is held in place with 4 1/4 inch screws remove them
lift up on the filter housing and pull forward you will find the sand inside the filter housing use a vac to **** it out and reassemble the dryer, no more sand
Apr 26, 2008 | Dryers
Frigidaire dryer
Most appliance stores sell a brush tahts on a 3 foot handle to remove any excessive lint form the lint trap.
Sep 16, 2007 | Frigidaire GLEQ642A Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
70 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
