I have a hotpoint WF740 washing machine showing an error of F -80, this came up after I had removed the blockage from the cone filter near the pump, i have checked for any further blockages but it seems complettely clear. the original problem was the machine would never complete and would stop with 1 min left to complete that is why i searched for a blockage, now I am left with F80 error code, can anyone help, thnk you
  • 2 more comments
  • tmpcontracto Nov 07, 2010
    sorry it is F 08
    Hi Just to clarify the error is F 08 not 80, thnks
    ok thank you for your help, tony
    very helpful, thank you
  • 10,515 Answers
Kindly clarify - Is it F08 or F80?
Thanks!!
Posted on Nov 07, 2010
  • taran_2005
    taran_2005 Nov 07, 2010
    Thanks for your response!!
    F-08 fault: static heater relay contacts are welded closed!!
    F-08 says that the Board is faulty, its a Heater relay fault.The only thing you can do is to test the heater, and see if it is OK.If not, then there is not much you can do, except call an engineer. I
    know it would cost you but that is the best option available as many
    people are facing similar problem with their Hotpoint machines as well.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
Where is the filter on my wf740 hotpoint
Maybe something jambed in pump, lint , coin or similar. Just fixed my LG machine coin in pump..Unsure of layout on Hotpoint but simply follow drain hose to pump.
Apr 17, 2013 | Washing Machines
My hotpoint washing machine is showing error code F05
Hi
Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer. Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved.
Hope this helps... Please post back for further assistance.
Daniel
Apr 18, 2011 | Hotpoint Washing Machines
Hotpoint ultima washing machine showing fault code f-05 and door will not open.
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code F-05 showing on my Hotpoint ultima
Error code F02 indicates pressure switch jammed on full.
Remove large black hose from bottom of drum.
Remove hose on to pump and check for blockage or obstruction here as well.
Pleas rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Door/drum seal has split causing a major leak also had probs for last few months where it gets to last 10 mins of cycle then it just counts down and doesnt complete the cycle it then gets stuck on 1 min...
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 18, 2009 | Hotpoint Aquarius WD640 Front Load...
Error 15 on a Hotpoint WM72 Washing Machine
The problem is your pump or filter is blocked,
Remove rear cover of washer, and remove large black hose from tub, remove and clean filter inside hose, check for a blockage in pump, refit filter and hose, and it should now be o/k.
Thanks.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf740 washing machine
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Oct 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Filter
most hotpoint have a hidden filter
take back bottom panel off. you will see a large diameter hose coming from tub to pump. undo hose at tub end. filter is inside this hose. take it out and clean it
Jun 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
