Question about Samsung MT1066SS Convection/Microwave Oven
My phone block ask puk code - Samsung MT1066SS Convection/Microwave Oven
  • 944 Answers
PUK code and PIN Code:
Please dont try more than 3 times.If you try more than 3 times the Sim will get locked.And it will ask for PIN code.Both these PUK and PIN code can be given only by the network service provider. Please call the network service provider of your mobile.And ask him to provide the PUK code or PIN code.He will ask you some basic details like name,date of birth for his verification.And he will provide you the PUK and PIN code.This is done for free of cost.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 05, 2011
HOW CAN I UNLOCK MY MICROWAVE? IT IS ASKING ME FOR A CODE
Press and hold unlock button for about 3 seconds. Look carefully on keypad, one of the touch buttons also says lock or something similar along with its normal function.
Nov 22, 2014 | Hamilton Beach Hb-P90d23al-Dj Microwave...
Redeem points - code 22026 Russell Hobbs slow cooker, in Palmerston North
What are you asking??? If you want to redeem points contact the manufacturer.
Sep 19, 2014 | Russell Hobbs Microwave Ovens
Complaints about Debit Order
you have to close your account immediately and ask your bank to give you all the information on who have been taking the money and where it is being sent. . sometimes it could be a mistake on the bank side but in this case I don't think so as when you block them they changed the amount. Also ask your bank what proof they have to withdraw money from your account line a void personal check or some form you signed. If the bank can't produce it then they are in the wrong.
Jul 02, 2014 | Microwave Ovens
What does e3 mean on a Samsung microwave
Temperature of exhaust air too
High
Let it cool down?
Cause:
The oven cavity gets too hot due to excessive
operation with no load or small load, or due to
some blocking materials around the Air Filter or
Air Exhaust at the back of the oven.
Remedy: • Open the oven door and check if 1) the oven
has been operating with no load or too small
load, 2) the air filter is placed in a wrong
position, or 3) any blocking materials exist
around the Air Exhaust. Cool down the oven (for
approx. 30 min) under the normal temperature.
The oven is back to normal when the error
code "E3" disappears and "ON" appears again
in the display window.
• Unplug the power cord, remove the blocking
materials around the ventilation openings, cool
down the oven (for approx. 30 min) sufficiently,
plug the power cord in again and check if the
error code appears again.
• If the symptom persists even when the oven is
cooled down sufficiently, contact the nearest
service centre
Jun 26, 2014 | Samsung MW1080STA Microwave Oven
Trim kit doesn't stick + front trim frame blocks the side vent
No no CVRS,
Where I live ...
No screws in that duct is a code violation
SO rather than support an operation that is
nationally recognized as a source of KITCHEN
fires...
Perhaps you should consider hiring the work
out to a PROFESSIONAL... Like your life depends on it.
Normally I support all kinds of daring DO-IT-YOURSELF
projects...
Not here... Not today!
Carnac the Magnificent
Jun 26, 2017 | GE Microwave Ovens
The control panel displays code F5 and I'm not sure how to fix this problem
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Jun 18, 2010 | GE Spacemaker JVM1540 Microwave Oven
ONLY 3 YEARS OLD, SHUTS OFF COMPLETELY AFTER ABOUT 3 MINUTES, THEN DISPLAY COMES BACK ON ASKING TO SET CLOCK
How long does it stay off? 30 to 60 minutes?? Sounds like the cooling fan is not working or air vents on the unit are blocked.... I saw one unit years ago with this complaint that when the customer turned on the MWO, the fan came on and pulled a curtain covering the pantry up to it, blocking the air flow and causing it to overheat and shut off....
Sep 11, 2009 | GE Microwave Ovens
F3 code on GE
ok here is the result to searching GE the answer to thew code.
Please rate our help to keep this free service online
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Aug 28, 2009 | GE JVM1430 Microwave Oven
Samsung MT1066SS Convection/Microwave Oven Logo
73 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
