Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
I get a flashing light, amber/orange and a clicking sound thats in sync with it. I cannot access any data from the hard drive and it doesn't seem to be recognized on the pc.
    Brigadier General:
  • 10,406 Answers
The Passport has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the Passport, at minimal cost to you.
Posted on Nov 07, 2010
I'm running it on a laptop with windows vista home edition. All worked well until I dropped it. The pc doesn't detect it anymore, the blue lights don't flicker anymore, and it makes a ticking...
Dropping a hard drive is never a good thing. They are very sensitive moving parts inside a hard drive and they don't take well to falls. It sounds to me like there was some damage when you dropped it and it may no longer work properly. The clicking is the hard drive trying to read the data and failing. You mentioned that it seemed to come back to life a couple of times...try and recover the data if you can, and contact Western Digital Tech support if you are still under warranty. Hope that helps!
Aug 25, 2011 | Western Digital My Book Essential Edition...
I just purchased a StoreJet 2M 320 GB drive. I would like to format it for use with my iMac. The MAC software doesn't seem to have a solution. How do I format the drive?
When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it using a computer with Windows OS. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy. You need to format the flash or external drive. Format thedrive as primary drive and in FAT32. (FAT32 will allow data to be exchangedbetween MACs and PCs also between XP/Vista and earlier versions of Windows).
Jul 06, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Alarm is going off. When I open it and look at the 6 hard drives inside the top one doesn't have a green light on, instead it is flashing orange and green. How do I fix this?
Remove the drive and clone it to a new one or use the raid software to rebuild to a new one.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Acer Altos G510 Server
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Can't access my Verbatim 2.0 Flash Drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 19, 2009 | Verbatim USB 2.0 HD DRIVE 12GB STORENGO 12...
HP Laptop(Compaq nx6310) Lights are blinking
You did not specify if you are talking about the lights below the screen or the ones at the front of the palm rest.
Have a look at pages 1-2 to 1-5 in the HP support manual (link).
The description might help you.
It seems to me that you are talking about the battery light (which is amber when the battery is charging) and the light for the drive (which is blinking when the hard drive or optical (CD/DVD) drive is in use.)
Just as a side note: if your hard drive light is constantly blinking, although the CD/DVD drive is empty AND you are not saving or accessing data - this could be a caused by not having enough RAM installed. In this case, the excessive memory has to be written to your hard drive, which could result in excessive blinking of that light.
Feb 20, 2009 | HP Compaq nx6310 Notebook
Lacie 500Gb Hard Drive Porsche design
Hallo,
my disk, when on, is not recognised by Windows while the light is flashing between yellow and orange fast (like a car's flash -faster-). please could anyone help me? - i need my data!
Thank you.
Aug 21, 2008 | LaCie 500GB FireWire-400 Porsche - 7.2K...
Flashing orange light
Power edge system are having two power input check the cables from the power outlet may be one is in contact otherwise one of your power supply gone means not working. Check the wires first then the power supply units
Nov 26, 2007 | Dell PowerEdge 1800 Server
Hard Drive not responding
The clicking sound you hear is unfortunately the death rattle of a hard drive. The sound is a regular click, click, click. This is because the heads of the drive can no longer find or read the sync track on the drive and usually means all the data on the drive is unrecoverable by external means. Hard drive labs can recover data from these disk failures but it requires them to dismantle the drive and that is usually a very expensive upwards of several hunderd dollars depending upon the amount of data recovered. You can purchase a replacement drive for the case and install it yourself if youare brave enough, for less than the cost of the complete package if you are good with a screwdriver.
Jun 27, 2007 | Trekstor DataStation maxi y.uh 400 GB USB...
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
197 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
