Question about Sharper Image SI686 Clock Radio
Need 12 hour setting instead of 24 hour - Sharper Image SI686 Clock Radio
    Problem Solver:
  • 11 Answers
I owned mine for years. This seems to happen when the power goes out. Push the mode button twice to get into the time set section. Once you are there, just keep pushing the mode button until the "pm" notification shows up on the digital display in the upper left corner. Once you get that use the 1-4 keys to set the clock. Good luck.
Posted on Jan 07, 2011
Change 24 hour clock non military time
You could select the 12 Hour clock mode instead of 24 hour as it may be set at now.
Also it needs to be confirmed if the audio system fitted to your vehicle supports 12 hour clock. Please check the two documents below after turning to the section on Clock setting. The menus to set this could vary depending on which audio system you have.
http://www.landrover.com/imagery/market/us/en/pdfs/range-rover-quick-start-guide
http://www.landrover.com/imagery/market/us/en/pdfs/range-rover-sport-quick-start-guide
Aug 29, 2014 | 2007 Land Rover Range Rover Supercharged
Date change
Hi.
I take it that your watch changes date at 12 noon, instead of 12 midnight.
If so change the time of your watch 12 hours, so it reads the same time, but instead of am, it is pm, or visa versa. Analog watches do not have a 24 hour time setting.
Jan 30, 2014 | Tissot Watches
Canon PowerShot SD4000 IS - How do I set the time for a 12-hour clock instead of a 24-hour clock?
I found that there is no specific way to switch it to 12 hour time vs. 24 hour military time.
Just found the instructions for setting the time from the menu.
Dec 26, 2010 | Canon SD4000 IS IXUS 300 HS Digital Camera
How do you get the time from military to normal? and how do yo set the date and time?
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
Sep 19, 2010 | Watches
How do you change the time setting to 24 hours?
  • Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  • Step 2 Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  • Step 3 Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  • Step 4 Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  • Step 5 Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
  • Aug 17, 2010 | Columbia All Sport Digi Watch l
    I need to change the atomic clock from military time to standard 12-hour format...can't find original manual...have owned the Radio Shack clock for 5 years.
    Hit the set button until the number 24 shows up instead of the time. Hit the "+" button once, and it will switch from 24-hour to 12-hour display. Hit the set button to cycle through the rest of the settings.
    Jun 22, 2010 | SkyScan 86709 Atomic Wall Clock
    The time on my vr3 cd player is set as military time how do i switch it back?
    it is probably set on 24 hour instead of 12... go back in and reset the time.... hold the hours down until you reach the desired hour..... you may have to pass through the 24 hours to get to the 12 hours
    Mar 22, 2010 | Virtual Reality Sound VR3 CD Player w/ USB...
    Setting the time to 12hr instead of 24hr
    according to my manual there isn't an option for 12 hour settings only the 24. I know, it's pretty dumb!
    Mar 25, 2009 | Protron PD-DVR100 DVD Recorder
    Reads 24 hr instead of am and pm
    Push and hold alarm time button to bring up “SETUP MENU”. Push the right tune ">"button 3 times and that should bring up the 12/24 hour display. Push the time + button to set back to 12 hour time.
    Mar 05, 2009 | Bose Wave Radio
    Aquatech watch
    press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
    press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
    hope this helps
    jeff
    Jul 23, 2008 | Watches
    Sharper Image SI686 Clock Radio Logo
    96 people viewed this question
    Top Sharper Image Audio Players & Recorders Experts
    woodzowl307
    Tom Chichester
    Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
