Question about EliteGroup ECS P4M900T-M2 Socket 775 Motherboard
Need to connect the power buttons and accessories
  • 4,737 Answers
This is the Labelled connectors of the front panel headers:
TOP = Left to Right = 2 - 4 - 6 - 8 - 10
BOTTOM = Left to Right = 1 - 3 - 5 - 7 - 9
and the pins should be connected in the sequence as shown below:
TOP = L to R = PLED = PLED (Power Led) and PWR+GND (Power switch)
BOTTOM = L to R = HDLED+HDLED (Hard disk LED) and Ground + Reset (Reset Switch)
If you have problem following my instructions, let me know with more details.
Good luck.
Thanks for using FixYa.
Posted on Nov 07, 2010
Connection error code 756
If you are doing this wirelessly then you need to look for a small slider button on the computer the enables/disables wireless connections. A light should come on showing it is on.
Mar 02, 2014 | HEWLETT-PACKARD Presario V6000...
I have toshiba laptop m55s3512 when i plug my laptop to power it shows only blue led only when i press my laptop power button nothing Else
First of all try to connect all wires properly in plug. Although, if you are facing same problem than wire can be damaged or not connecting. So, you need to visit retailer.
Aug 31, 2013 | Lifetime Toshiba Satellite M55S3512...
Jensen vm9214 when i hook my indash to battery only the src button is red it wont turn on t
Did you connect the power, ground and accessory? When doing a bench test for operation, these wires need to be connected.
Sep 30, 2012 | Jensen Vm9214 Car Video Player
My iphone 4 wont connect to my computer
Try the following:
1- try another device using the same cable.
2-Try to reboot your device.
3- You need to press both Power key and home button for 7 seconds.
May 29, 2012 | Apple iPhone4 4G iPhone 4
How do i connect it to my wii
To connect a Wii accessory to the console, you need to sync them to each other. Doing this is easy.
Generally, you can find the sync button under the battery cover on accessories, which should be a small red button. Look around your remote for it.
After you find your sync button on your remote, find the one on the Wii. It is above the SD slot, and you will have to pull open the cover to see it, which is the little rectangular cover on the front of the Wii right underneath the power and reset buttons. The sync button is the little red one.
Once you've found both buttons, hold them both down at the same time for about 3 seconds, then let go and the two should sync with each other. You only need to do this once and you should be fine.
Apr 16, 2011 | Hipstreet Wii Hip Street Wireless Remote -...
Wii fit board blinks but will not connect, brand new first time using with new batteries
You need to press the red sync button located inside the battery panel with the power on. Then turn board over and let it connect to the console.
Apr 03, 2011 | Nintendo Wii Fit for Wii
When I turn on the ipod it says locked and disabled and connect to itunes! what do I do to unlock and reconnect??
Plug the iPod touch into the computer with the USB Dock connector. Once it is connected to the computer turn off the iPod touch by holding the power button down on the top of the device until you see the "Slide to Power Off" on the screen. Power Off the Device. Once the device is off (and still plugged in) hold down the home button and keep holding it while pressing the power button to turn on the device. Continue holding the home button until you see the screen on the iPod Touch Say "Connect to iTunes" at which point you should launch iTunes on your PC/Mac if it has not already loaded.
Mar 02, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
TOSHIBA SATELLITE M55-S3512 LAPTOP LCD SCREEN is red then it switches off. When I close and reopen the lid the screen turns on for 3 secondes then goes off. Do I need to change the lcd?
hi,
Please try to remove the battery and the AC adapter then press and hold the power button or the on/off button for one minute. Basically,it will not turn on since there is no power supply connected. After one minute, connect the laptop directly to the power outlet without using the battery just for the meantime then power on the laptop, if this will not fixed the problem, you will need to replaced the LCD cable or the LCD itself.
Hope this will help...
Jan 08, 2011 | Toshiba SATELLITE K000080220 LAPTOP LCD...
Trying to install a push button ignition need to know which two wires to run to the button, without having to spend hours tracing and guessing. A diagram showing the wires would be great.
Your switch has 4 terminals.
1. Red is the hot wire from the battery.
2. Dark Blue is the run wire. This wire powers PCM, and engine and well as all accessories when the key is on.
3. Yellow is the start wire. It powers the engine, ECU and starter circuit when the key is turned to start.
4. Last terminal is accessories. I don't know the color, but it will power the radio, blower, windows, mirrors, etc. when key is turned to ACC. Some diagrams of the switch are below. Please let me know if you have any questions.
Nov 12, 2010 | 1996 Dodge Dakota
ALL MY MUSIC IS GONE! BUT ON ITUNES IT SAYS ITS STILL THERE! How cani fix this?
ResetTo reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
  • Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jun 21, 2010 | Apple 160 GB iPod Classic (Silver) +...
EliteGroup ECS P4M900T-M2 Socket 775 Motherboard Logo
1,884 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
