Hello, I have an LG LHD65EBL that will run for a few minutes when turned on and then I can hear the fan and compressor shut off, but I still hear a humming noise and it smells like it's burning. Time for a new one or is it repairable? Thanks, Jim NJ
  • dogsofwar Nov 07, 2010
  • dogsofwar Nov 08, 2010
    I took the fan motor out and cleaned it all up, oiled it and it worked for a few hours and then quit again. Time for a new one. Thanks for the tip!
  • 43,501 Answers
Hi.
Yes, it is probably best to replace it...
The problem is probably the fan motor....and while it is technically repairable, the cost would be more then it is worth when comparing the repair cost to new....
A quick search shows pricing in the 200 buck ball park...
Till you pay 100 bucks for that motor and then figure labor.... you get the picture...
Wish I could give you better news...
heatman101
Posted on Nov 07, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 08, 2010
    Yeah, you can usually get them running a bit but it is only temporary...:-)
  • 3,083 Answers
It's either a fan or compressor failure, sounds like. You might contact an A/C repair shop to see how much they would fix it for, then price a new unit, and go from there. The burning is probably motor windings shorting out in the compressor, which can be costly.
Check with a shop, but take in to account all factors (age of your unit, condition), and determine if it's feasible to repair or replace.
Good luck, and hope this helps.
We LG LHD65EBL and we cant turned off either we can control the level of humudity
if by turn off do you mean make the fan stop running ? if so sometime in the past few years someone decided to make machines like this run the fan all the time , but they do cycle the compressor motor to regulate the rooms humidity level
May 26, 2015 | LG LHD65EBL Dehumidifier
Error code 67
Error code 67 is an airflow problem. Either clogged filter or bad blower motor. Unplug unit remove bucket and feel for filter in front behind cover it drops down. Clean filter with water and reinsert. Plug unit in turn to "on", fan should begin to run, after 3-5 minutes compressor should start. If fan does not start it is bad and should be replaced.
Jul 07, 2012 | LG LHD65EBL Dehumidifier
I have an LG model LHD65EBL dehumidifier. The humidistat will not change from 70 when I push either + or -. The fan runs well and the compressor sounds like it is running well Some water comes out when the...
Prt of the problem may be a dirty or clogged air intake filter.
Turn the unit OFF and unplug, it before removing the filter to check and clean it.
You can ether vacuum it or if it's really dirty & clogged, wash it in warm water and mild dish washing liquid. Rinse thoroughly, shake off access water and allow it to dry completely, before reinstalling it.
Never operate the unit without the filter in place. As this could damage the unit.
Plug the unit back in and turn it ON. Try lowering the humidity extraction level now, using the arrow down button. For a very damp, humid basement application 35% is a good setting to start with for several days.
Hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | LG LHD65EBL Dehumidifier
I purchased a 65 pint LG dehumidifer # LG LHD65EBL. This is the second one that I have had. I had to return the first one because it would not shut off when bucket was full. This one runs for about a...
First, tunr the unit OFF and unplug it for 10 minutes. Then plug it back in and turn it ON. It will automatically set at 70%. Press the - button and lower the humidity extraction level to 45% in increments of 5%. Once you reach 35% press and the - button one more time. Now the unit is set to run continuously, until the bucket is full and the unit turns OFF automatically or you manually turn the unit OFF. In case you have misplaced the Owner's Manual, I have included a link to it, that you can download and print. http://aic.lgservice.com/gcsc/dwn/main
I hope this helped you and thanks for choosing FixYa..
Jul 29, 2011 | LG LHD65EBL Dehumidifier
When running load noise coming from black cylinder
That part you identified is the compressor of the dehumidifier. Compressor is probably bad or going bad. When compressor go bad the valves start making noise and they lose alot of there efficiency.
Dec 10, 2009 | LG LHD65EBL Dehumidifier
I have an LG dehumidifier model #LHD65EL it runs none stop and doesn't collect any water
Make sure your coil and fan is clean and verify that the compressor is coming on.
Oct 02, 2009 | LG LHD65EBL Dehumidifier
Everything seems to run fine, just hasn't pulled a drop of water
remove the back airfilter, and touch the tubes while the unit is running, if nice and cold, all is well, there just isnt any moisture there. but if compressor is running and tubes are warm , means freon/coolant has leaked out
Jul 22, 2009 | LG LHD65EBL Dehumidifier
LG PTAC acting strange in heat mode
I believe the problem in lies in the dual stage heat mode setup on the thermostat, but the unit going into defrost does make the unit act kinda strange. Even more so than other types of equipment. I would suggest hiring a licensed HVAC service technician if the problem cannot be resolved by yourself.
Dec 15, 2008 | LG LP120HED Wall/Window Air Conditioner
LG dehumidifier
I Have an LG Dehumidifier and water has leaked out to the basement floor, it has a hose that drains into the floor
Sep 12, 2008 | LG LHD65EBL Dehumidifier
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Marvin
Marvin
