Question about BuddyPoke
The application does not start up; instead, it shows this: Version: 1.197 Loading User: 24% Loading Avatar: 100% Loading Interface: 0%
Tip
A Brief History of Norton Anti-virus
Norton anti-virus is a product of Symantec Corporation. Norton anti-virus helps you to remove viruses and malicious codes from your computer, it also protect you from online threats. Symantec programmed and launched various versions of Norton anti-virus to protect your pc and Internet Security to secure your online activities from hackers.
As per history of Norton products, it's about 25 years before Norton antivirus came on the market. The name of the first Norton anti-virus was Norton Commander, released in the year 1986, served as a standard interface for DOS. This version of Norton was invented to protect DOS from malicious programs. Norton Commander was a prototypical orthodox file manager, written by John Socha and released by Peter Norton.
Norton Commander is considered easy to use based on its constant view of two file manipulation objects at once. After starting the program the user sees two panels with file lists. Each panel can be easily configured to show information about the other panel, a directory tree, or a number of other options.
When Symantec acquired Peter Norton Computing from Peter Norton, Norton starts to develop various utilities or applications for DOS, as well as for Windows. Product activation was introduced in Norton anti-virus 2004. Spyware and adware detection and removal tool was introduced to the 2005 version. The redesign main graphical user interface and homepage hijacking protection was released with 2006 version of Norton anti-virus. With the version of 2007 windows 2000 compatibility was dropped and Vista compatibility was introduced, with anti-rootkit technology. Version 2009 and 2010 released with Sonar protection, File Insight, and rogue security software tools. The latest version of Norton anti-virus is 2011, which protect your computer being infected from facebook wall and feed.
on Mar 17, 2011 | Computers & Internet
The application preferences file is damaged. Please remove it and re-launch QuarkExpress [297] Where is the preferences file located? (Version 9, Windows 7)
The preferences file will be in the User\AppData folder.
C:\Users\ your user name\AppData\ Local\Quark\QuarkXPress 7 is the location in Vista with version 7 and it should have a similar location in Windows 7.
C:\Users\ your user name\AppData\ Local\Quark\QuarkXPress 9 is likely. (AppData has 3 folders - Local, Local Low and Roaming.)
You should not delete the folder. Instead rename it. Right click on the folder and select Rename. Then name it
old_QuarkXPress 9.
This could be a hidden file. If you click Start and then enter Show hidden folders. Then put the bullet on Show hidden files, folders and drives. Then click Apply and OK.
If moving the AppData location to another folder doesn't solve the problem, check if there is a Preferences file in the Program Files folder (
C:\ Program Files\ Quark\ QuarkXPress 7.x for the old version.) If the new version is built for the 64-bit OS, it might be in the x64 Program File folder. Again rename the file if it is in that directory.
I hope this helps.
May 14, 2011 | Computers & Internet
What does gui means?
GUI is a Graphical User Interface, which is for making "Windowed" Applications.
Nov 01, 2010 | Microsoft Internet Explorer 8
Kenmore elite he3 dryer says PF
The PF and E2 (F02) error codes are related. The PF indicates that the dryer is experiencing a power failure. The F-02 error code indicates a Keypad/User Interface failure. The error codes for this dryer are shown in the third image below.
You could have a loose wire harness connection between the machine control board and the user interface control board that could cause there error messages and symptoms. The first image below shows how to access these components. I recommend that you unplug the dryer and then access these components. Check the wire harness connections on between the user interface control board and the machine control board. If the connections are okay then you will likely need to replace the user interface control board to correct this problem. The part number for the user interface control board is 8564396. You can order this part from the Sears PartsDirect website. It costs just over $100.
Sep 20, 2010 | Kenmore Dryers
Every time I turn on safari starts auto, get error that toolbar does not support my version of safari.
update your safari to latest version,
but I use Firefox on my mac,why not try it?
Aug 01, 2010 | Apple iMac G4 Desktop
Windows 7 64bit ultimate edition Lots of ''Application Error''
asus M2N68-AM PLUS motherboard is supports all operating system but intel is not support win 7 64bit
May 13, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
What is the difference between the Dos download and the windows download as there is 23 mb difference.
What application are you talking about?
Windows uses a different set of hardware drivers and completely different user interface software. Windows applications "call" standard methods to display menus, windows etc instead of including them inside the application. Most windows applications are larger than the dos equivalent because windows is "bigger" that ms-dos. Windows supports cutting and pasting between applications.
Dos usually has to have each application load its own drivers and its own user interface software. Often a dos application is smaller and sometimes less functional than the windows equivalent. Cutting and pasting between Dos applications is tricky and often involves "exporting" from one application and "importing" to the next via external files that you have save and locate.
Oct 08, 2009 | Computers & Internet
Kenmore Oasis Elite Top Loading Washer with an F2 error
The F02 error code indicates keypad/user interface failure. Most of the time, this is caused by a problem in the keypad/user interface. It can sometimes be caused by a failed control board.You could have an intermittent problem such as a stuck key or contact. As long as the F02 is not displayed, the washer should work normally. You can continue to use it when the F02 is not displayed. It is still safe to use the washer.
Sometimes this problem is caused by a loose wiring harness connection between the keypad/user interface control board and the machine control board.
The F2 error code on this washer indicates a stuck button on the user interface control board. The procedure for accessing the control boards on this washer is shown in the image below. I recommend unplugging the washerand checking the wire harness connection from the user interface control board to the machine control board. Try unplugging the connections and then plugging them back in a few times. Make sure that they are plugged in correctly and then reassemble and test the washer. If the F2 is still displayed, then the user interface control board will need to be replaced.
CLICK ON THIS LINK TO GET THE INSTRUCTIONS HOW TO REMOVE CONTROL BOARD:--
http://media.fotki.com/1_p,wfbgkftgqtgssggxgtqsskgwtqkq,vi/gdqwksfbdxggskbksbb/1/1303472/5961857/image8028img-or.gif
You can order a new user interface control board from the Sears PartsDirect website or from----------
www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jan 12, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I want to know the meaning northgate/iworld, the way it's used and what it is used for
It is a distributed database application (Sx3/Northgate iWorld) that went live in May 2004 for 100+ users. Issues included; project planning, risk assessment, data cleansing, data loading (in the region of 50 million records), data archiving, development of output, testing, interfacing, security, end-user training, procedural change, progress reports, presentations and the configuration of both the back-end server and the end-user WUI (Web User Interface). The system is three-tiered, with a back-end Oracle database linked to an application server feeding a JVM/J-initiator applet on the client machine.
Apr 27, 2008 | Computers & Internet
BuddyPoke Logo
Top BuddyPoke Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a BuddyPoke Facebook App Expert? Answer questions, earn points and help others
