Question about Garmin StreetPilot i3 GPS Receiver
Garmin street pilot13
The system has lost all map data how do i reinstall it
  • 3 Answers
You will need the original mapsource disks and your 25digit unlock code.
Posted on Aug 22, 2008
Garmin nuvi 200 problems- I press streets icon ----it comes up (NO DATA AVAILABLE).
Make sure that your map is enabled with a check mark on the map info screen. If the map info button is grayed out, then this means that your map is missing.
Jul 08, 2013 | Garmin nuvi 200W GPS Receiver
My gps doesnt show all the streets
Sometimes it will not all the streets, especially main streets, unless is zoomed in, try the zoom feature in and out, or three 3 d or 2 d feature.
Jun 11, 2011 | Garmin nuvi 1490T GPS Receiver
Hi, I have a Nuvi 255 (205 series) gps, three years old. Last week the screen went blank, came back grey with 'crosshairs' and a black dot in the middle indicating 'press here'. I did so and the dot moved...
Graham - what your describing sounds like you somehow managed to erase the street level maps and POIs in your Nuvi.
If you connect the GPS to the computer with your USB cable, you should at the contents of the Nuvi directories and find a file called GMAPPROM.IMG or GMAPSUPP.IMG. These are the street level map files. Generally, these are found in the root directory of the Nuvi - or if yours has / and you use a memory card slot for maps - find it in the /GARMIN directory. GMAPPROM.IMG is the name of the first map set and GMAPSUPP.IMG is the name of the supplementary or second map set (if you purchased & installed one). You will likely have only one of these files - and may be named either. The size of this file depends on the area and age of the map. Current maps of the entire US run over 1 GB in size. If you do not have any maps named GMAPPROM or GMAPSUPP, you will not see any street level maps.
Something happened to delete the maps. Garmin will probably NOT provide free replacement maps for you, unless under warranty. If the devices is trashing maps and other files, you probably want to replace the unit under warranty or not. Garmin will, upon return of your old Nuvi - replace it with a factory refurbished unit with the latest maps installed, for $79. You can take advantage of this service by following this link to Garmin Service.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Garmin nuvi 205 GPS Receiver
I have no maps on the screen its like i lost all the data. it says there are no roads near this start point. every thing else works mp3, settings, volume, bluetooth, etc.
it sounds like you may have just deselected the maps.
go to tools settings map then map info(bottom of the screen)
check that there is a tick next to your mapset if not just tap the name of the map and you should be sorted out.
Jul 12, 2010 | Garmin Nuvi 660 GPS Receiver
Address not comming up
The garmin is only as good as the data that was given by every municipality. If this is happening alot I recommend the following:
1. reset your unit. To do this carefully use a fingernail to pry off the frame around the screen. There you will see a reset button. push it. then replace the frame.
2. If this does not solve the problem you will have to download the data again. to do that you will need the disc that came with your garmin and a computer.
Please rate my answer as a FixYa! Thank you.
Feb 04, 2009 | Garmin nuvi 200W GPS Receiver
How can Iupagrad the map
is this harman or garmin? if garmin go to garmin web site. you have to join w/user name and all. i think a fee of $25 is required. you can download new maps to a memory card to install on your gps. mike
Nov 18, 2008 | Harman Kardon GPS510 GPS
Update 2009 for Street Pilot c330
2009 upgrade data is too large for garmin 330 must have sd card
Jun 08, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot III map source data card not accessible
Garmin has issues with the newer (ROHS Compliant) cards, so If you recently bought this card get a replacement from garmin.
I had these issues too with a 256 MB, garmin replace the card with 2 128MB cards, worked fine after that.
Mar 26, 2008 | Garmin Streetpilot ColorMap GPS Receiver
Maps Update 2008 North America Problem
Turn on the Garmin. Look for the little wrench on the screen and select it. Now look for Map, select Map. Now look for "Map Info", select Map Info. Verify that there is a check mark next to City Navigator North America NT
Dec 30, 2007 | Garmin StreetPilot c550 GPS Receiver
Street Map Program for Garmin GPSMAP 295
Detailed road map data, with addresses, hotels, gas stations, etc. can be loaded into a data-card/cartridge/memory-card using Garmin's Mapsource software such as Metroguide or City Navigator. This can be changed as needed via a PC.
The 295 does not have driving routing/guidance through the streets as most of today's GPSs have, but it will show you exactly where you are on the street (but it should be switched to Road mode).
Driving routing is possible on the PC using Mapsource, but ithe route doesn't transfer well to the 295 because of the limits on waypoints.
Nov 29, 2007 | Garmin GPSMAP 295 GPS Receiver
Garmin StreetPilot i3 GPS Receiver Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
