Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice maker Our automatic ice maker is not working in our kenmore refridgerator, the water is going to it just fine it just won't make ice cubes
    Scholar:
  • 52 Answers
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Posted on Jul 18, 2008
  • 4 Answers
IS YOUR FREEZER COOLING TO O.F
Posted on Jun 15, 2008
Is there a water filter in my 7102 kenmore refridgerator
There could be one in the water line that feeds the ice maker.
Apr 03, 2014 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I was told that my new refridgerator will come with an automatic ice maker. What does that mean?
These days, modern fridges come with automatic ice makers that are built into the fridge itself. The fridge automatically fills the ice holders with water that then freeze into cubes. You can then tip the ice onto a tray that is removable and then the fridge will automatically re-fill.
Feb 18, 2013 | Home
Where do I connect the water hose in the back for the refridgerator
what kind of water hose.this ice maker should fit 3/8 cut off value and sit in the back at the bottom
Oct 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refridgerator is warm, freezer is freezing
Defrost problem. Most likely the defrost heater or defrost thermostat.
Jul 02, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water in automatic ice maker, therefore no ice cubes.
Do you get water at the front dispensor, if present? If not check the refrigerator water filter. If you have an RO system feeding filtered water to the fridge, check it's filter. Also there is a solenoid that lets water into the ice cube maker, have a professional check it to make sure its working correctly. Lastly I have had to replace the entire ice cube maker, sometimes they do fail. Replacements can be found fairly easy on the internet.
Feb 21, 2010 | KitchenAid KUIS18NNT 18" Automatic Ice...
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working properly
Make sure the fill tube going directly into the icemaker is not touching the part that receives the water, if it is touching the water will spray all over and not go into the cavity
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Ice maker not dumping ice
The freezer has to reach a certain temp. in order to freeze ive. You might have to wait overnight for ive-- keep the freezer closed.
Aug 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
120 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
