Back to:
Tags:
Microsoft Xbox Console
Xbox hdd upgrade (by 3 users)
posted by AC SPECIAL on Jun 15, 2008
I used xboxhdm 2 create a new hdd 4 my xbox now i get error 08
Comment by AC SPECIAL, posted on Jun 28, 2008
I LL try Chimp but I think it locks fine if I dont lock it i get error 5
Comment by AC SPECIAL, posted on Jun 29, 2008
when i lock it I dont get error 5 I get error 8 when I tried not locking it then i got 5.. ALso do i need 2 us Config magic to flash my eeprom so it matches with the new hdd ? ? ?
With no hdd in at all then i get error 9.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by kona4999, posted on Jul 12, 2008
I have an error 05
What do i do?
Comment by Guest, posted on Jul 12, 2008
I have error 05
what do I do?
Best Solution
posted on Jun 19, 2008
Helpful (85)
sanjuro77
Rank:Wiz Wiz
Rating: 96%, 15 votes
Xbox error message 08 means "No HDD found". When you set up your XboxHDM disk, did you remember to add both C + E files, and placed your eeprom.bin file in the correct folders before burning? If you did, try checking the jumper settings on your new HD. If your drive is larger than stock, you might want to add an F: drive partition, and if really big, add a G: partition too.
If you've done all this, try using an Xbox app named Chimp with your original drive, in case Xboxhdm didn't lock your new drive when it was finished writing the new files. This actually happened to me while I was dropping a 320G drive into one of my Xboxes, and Chimp was able to lock the drive without any hassles. Since then, the drive has been working just fine.
Comment by sanjuro77, posted on Jun 29, 2008
Yes, an error code of 05 means your Xbox drive is unlocked. Ask me if you have any more problems.
Comment by sanjuro77, posted on Jul 10, 2008
In this case you might want to try to just clone your old drive using Chimp.
Using Chimp:
Unlock your new HDD.
Fire up your Xbox normally, and start Chimp. Connect the new drive to some kind of power supply, another Xbox works fine, or you can use a PC, or even just a Y-adapter in the Xbox you're working on. If you're using another Xbox, make sure you put a video cable in it, it doesn't have to be in the TV, just in the Xbox. Otherwise it won't boot long enough to power the drive. It's okay if it flashes error messages via the LED lights, just make sure the new drive is being powered.
Now, while Chimp is waiting, unplug the IDE cable from the DVD-drive and put in in your new drive, but leave the DVD drive powered. You don't have to be too quick, so be sure not to bend any pins. Now have Chimp scan for devices. It should show you the HDDs in your Xbox. If it shows your new one, you're ready to clone. Now tell Chimp to clone/copy your drive. When it's done, lock it, and unplug everything and plug your Xbox back together normally with the new drive in it. It should work fine. If you're having trouble getting Chimp to recognize the new drive, it's either locked or the jumper settings need to be checked on the HDDs.
Comment by sanjuro77, posted on Jul 19, 2008
If you have the "eeprom.bin" file backed up, fixing an error 05 should be no problem. The HDD just needs to be "locked". The eeprom.bin files is like a key for this lock.
If you are making a new HDD, and still need to lock the new one but have the old one still, you can use Chimp.
Otherwise, you'll have to use XboxHDM.
If you don't have a copy of your eeprom file, you'll have to build a special chip that lets you read your eeprom.
Find everything you'll ever need here:
http://forums.xbox-scene.com/
Rating Locked! (?) AC SPECIAL has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on xbox hdd upgrade:
I don't want to Accept this solution
Solution #2
posted on Jul 03, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
unlock harddisk using a program like xbox hdm then format it to whatever u want using diskmanager in xp
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
posted on Jun 18, 2008
Not Rated (0)
Yurybodel
Rating: 0%, 0 votes
how do i format my xbox hard disk into my pc
Thank You!
Can you Help with these Video Game Consoles problems?
everytime i switch my xbox on the dashboard never appears,...
my original xbox turns on but then it says it needs to be...
trying to use wireless network but not loading
it goes to clock screen and thats it i press all the...
Is there a place to buy a used Xbox remote
Loading problems.
Repair Service
Find Video Game Console Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
