Question about Whirlpool MH2155XP Microwave Oven
I use a AVM 562 whirlpool microwave. It's working fine except that it doesn't heat up anything. When inquired about this to a local electrician he said that the power that is going to the microwave heater from touch pad is not proper. He asked me to replace it and he says it will cost 1500 Rs(indian rupees) for the same. What is the actual cost of it in India??
MicrowaveSvc
  • 9086 Answers
SOURCE: I have a Whirlpool AVM
You should be able to download your owner's manual (instructions for use) here.
Enter either all or part of the model number of the appliance (e.g. AFG 549) or the 12 digit numeric code, (usually starting with 85) that can be found on the service sticker of your appliance.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 13, 2008
biigg53566
  • 88 Answers
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Posted on Jan 03, 2009
scottowa
  • 87 Answers
SOURCE: Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Posted on Mar 04, 2009
bestdarngood
  • 3037 Answers
SOURCE: No heat but everything else works
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
SOURCE: Whirlpool Microwave Oven TALENT COMPACT made in
I took services of Whirlpool Service engineer who solved the problem satisfactorily. I do not know details.
I do not need your sevices for now. I shall contact you if I do.
Thanks
Posted on Dec 07, 2009
Whirlpool microwave AVM 585 - none of the control buttons are working, except the number 1.
The electronics on your control panel have gone bye bye. That is why to this date I have always preferred the nukes with the old fashioned timer. They always work and when anything goes it is the little motor that can be easily replaced at nominal cost..
Newer is not always better. Might look better but .....................
Sep 14, 2015 | Whirlpool Microwave Ovens
Everything on microwave works except it doesn't heat or cook. what is the problem?
IT'S THE MAGNITRON - CHEAPER TO BUY NEW THAN REPLACE - SORRY.
Jan 09, 2013 | Microwave Ovens
I have a Whirlpool wmh1162xvs2 Microwave Hood combo. Everything seems to be working fine except it is not heating the food. Please help!
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 =-
Aug 30, 2011 | Whirlpool WMH1162XVS Microwave Oven
I have a Whirlpool GH5176XPS microwave and everything seems to work fine except that it does not heat anything. I have checked all the fuses and they are fine. Any suggestions?
The problem is more than likely a bad magnetron, "heats food" the other two considerations are the high voltage capacitor and diode.
Mar 31, 2011 | Whirlpool GH5176XPS Microwave Oven
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Unit operates does not heat anything
A defective diode or magnetron can cause the oven to sound differently and not to cook.
Jun 19, 2010 | Whirlpool MH6130XEB/Q Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave will not heat
If all controls on the panel work fine but the microwave does not heat, then either you have a defective door switch,the smartboard is defective, or you have a defective magnatron.Most likely one of those three.
Nov 06, 2007 | Magic Chef CMV1000B Microwave Oven
Whirlpool MH2155XP Microwave Oven Logo
100 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
