Question about LaCie (300740) 160 GB Hard Drive
I have a Lacie 160GB external HD that seems to have power supply issues. When I plug it in an turn it on, the blue light comes on and "shimmers" - it's not a full glow, but it's not a flicker either. And, the drive doesn't start up at all. What solutions are there for this?
    Brigadier General:
  • 10,406 Answers
The Lacie has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Posted on Nov 07, 2010
Lacie Case Only lighting up when HD is disconnected
I had the same problem with a 1TB hard drive. The fault was caused by the casing being knocked from the computer and falling onto the desk. If the hard drive hadn't been powered up it would have been ok...
I removed the hard drive from the casing and fitted it into my computer as a slave drive, hoping to access all the music and movies stored in it. No go .. But, it's worth you fitting your hard drive as a slave and trying the same. It's worth a shot.
I took the hard drive to a computer market here in China, where I work. These guys take hard drives apart to fix them, if possible. They couldn't fix my hard drive as it had been powered on when it fell ..
However, I bought a new desktop hard drive and they were able to transfer 95% of all things from the old hard drive to the new one. The cost of transferring from the old hard drive to the new hard drive was the same as the price of the new hard drive. That specialist service doesn't come cheap ... but it can be done. I paid simply because I didn't want to lose what had taken more than a year to download.
Try fitting your hard drive as a slave to see if you can access the information on it. If not, a new hard drive and the cost of transferring your music from your old hard drive may be the only course of action left open to you
Jun 05, 2013 | LaCie Big Disk External USB 2.0 1TB Hard...
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
Imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Oct 17, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
My Mac suddenly cannot find my Lacie external storage device. I have turned off, unplugged, restarted... etc. and it is still not finding it. The Lacie seems to be on, at least the blue light is...
A continuous flashing light on a Lacie drive is a notification of a problem. I do wonder if the light is flashing the same if the drive is plugged in to the Mac or unplugged.
Lacie external drives tend to have power-supplies which become weak/bad. Most users replace the supply and it will work again for awhile until the supply dies again. Try bringing the drive to a retail dealer with Lacie drives -ask them if you can just test your drive with another power-supply (if you do not have another). You can also try calling Lacie, it's always slightly possible they will be aware of this problem.
Alternately, IF the light is only flashing when the drive is plugged-in to the computer, try using a different USB or Firewire cable.
Aug 31, 2009 | LaCie Computers & Internet
My 500GB LaCie will not power up
that is an external drive correct. It should run just off the usb. is the drive recognized ?
Robert
Aug 27, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
Lacie hard drive nonfunctional
I ran into this issue this week with my lacie big disk 500G external. Unit would power on when plugged into a pc blue light would flash and nothing no connection ding from windows.
Blue front light would flash repetedly slight ticking sound from drives but no connection i finally fixed this and gained access to my data by opening up the case and pluging my pc 12v connectors into both drives to power them up but leaving them connected to the lacie internals worked instantly and ive since copyed all my data off my 500 and will just transplant the drives to internal use on my pc. you cannot connect the drives internally and then copy the data due to the fact that they are raid 0 stripped drives so this hybrid setup works if your external case isnt powering up the drive correctly as mine wasnt.
Mar 02, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
I think I fried my LACIE 500gb drive
Sadly if you fried the drive with that PSU cord it would be pretty hard for a home repair. If you know its definatly dead, I would just remove the drive from the external unit and try to connect it internally to a computer. If the adaptor is different you could buy a cheapy online somewhere.
Jun 18, 2007 | LaCie (300740) 160 GB Hard Drive
LaCie Hard Drive
The hard drive has it's own power supply. If you look on the back of the external hard drive, there is a power button there to turn it off. It doesn't shut off just cause you disconnect it from the PC or turn the PC off.
Feb 01, 2007 | LaCie (300951U) 500 GB Hard Drive
Open Questions:
LaCie (300740) 160 GB Hard Drive Logo
165 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
