Question about RTO Cupless Devilbiss Gti-620g Millennium Hvlp Spray Gun
I have a devilbiss gti suction feed and for some reason my gun is putting pressure in the pot insteed of sucking the paint out. anyone have any ideas. Thanks Darrell
  • 7,733 Answers
It seems that for any reason the cables are inverted so try to (invert) change the cables poles.
Posted on Nov 09, 2010
I HAVE CLEANED MY DH3800 SPRAY GUN AND THE PAINT WILL HARDLEY COMES OUT I AM USING 60 PSI ON A LARGE COMPRESSOR WHAT AM I DOING WRONG AND THIS ONLY THE SECOND TIME THAT I HAVE USED IT ( AND THAT IS...
These guns are made to use about 35 - 45 lbs psi and the paint needs to be thinned a bit. You will have to experiment with the thinning for how much coverage, how much humidity, what type of paint and thinner it takes.
Sep 25, 2011 | Campbell Hausfeld Air Comp Basic Spray Gun...
I am using DeVILBISS JGA_510 cinventional spray gun. The pressure pot system is showing constant pressure , but the gun is sputtering and not getting an even paint flow. I have changed paint lines, put on...
First start with the basics, whats the paint VISCOCITY ON A FORD 4 CUP ??
Or Does it run nicely off the stick you stirred it with??
If its thin enough to go up the tube and lines, whats the fluid tip and air cap combo your using?? maybe start with a EX fluid tip (1.8mm) and 30b air cap (cos that sprays everything!!) and reduce from there.
Whats the pot pressure?? Is it a KBII pot? cos they suffered with the air inlet blocking, so IT SHOWS GOOD PRESSURE, but doesnt have it in the pot!
Does it spray anything?? thinners?
Mar 07, 2011 | Air Tools & Compressors
Air pressure out through the suction tube of liquid my spray gun - DeVilbiss jga 558
If your getting air down the suction pipe your air cap isnt tight enough or its the wrong one.
Oct 21, 2010 | Air Tools & Compressors
My paint gun is pulsating instead of spraying evenly
It looks like you have a Devilbiss SRI.
Probaby the hole in the lid is blocked, The gun sprays, paint gets sucked out, no air can get back in through the little hole in the lid to replace so it stops spraying, pressures even up it sprays abit more, and so on.
Either that or you have a damaged fluid tip.
regards
Sep 18, 2010 | HVLP New PROFESSIONAL AUTOMOTIVE AIR...
Unit does not draw from bottom cup
Both are gravity type spray guns, i.e. they cannot draw from a bottom (suction, siphon) cup.
Jul 25, 2010 | HVLP 2 DeVILBISS Auto Paint SPRAY GUNS...
Bubbles coming in to paint pot on my gavity feed gun please can you tell me how to solve the poblem
each time i have had trouble with my guns it will be trash or something keeping a seat from sealing off
Feb 12, 2010 | DeVilbiss FinishLine Gravity Feed Spray...
Binks bbr converting from pressure to siphon
Worked in paint repair shop for 18+ years. Every time we had that issue it was the wrong air cap. The particular model we always had trouble with was a Devilbiss JGA going from a pressurized system to a 1 quart cup. But the Devilbiss and Binks are quite similar.
The air cap from the pressurized system would actually cause a reverse pressure in the cup.
Both air caps were for this gun. Also the Devilbiss
rep said they should be interchangeable.
They weren't. Try a different air cap.
I'm kind of curious so please let me know if this works for your Binks.
Jul 31, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
RTO Cupless Devilbiss Gti-620g Millennium Hvlp Spray Gun Logo
251 people viewed this question
Top RTO Air Tools & Compressors Experts
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
