Question about Sharp LC-52D62U 52 in. LCD HDTV
My sharp lc52d62u turns on and imeiatly turns off. the problem has been getting worse and much more frequent in the last 2-3 weeks? the tv is 4 yrs old. did it after 1 yr 1 time every 3 weeks. no rhyme or reason to it at all
SOURCE: Sharp LCD HDTV Facedown Damaged
not sure i laid over a lcd for a couple mintues. that belong to my comapny, once i stood it back up the screen was cracked. i like to have fell over, the replacement part is 12266.00 i guess your out of luck. as i am.
Posted on Oct 25, 2007
  • 16 Answers
SOURCE: Sharp TV Audio Problem
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
Particular thanks are owed ‘Aureius’ of the AVS forums for his research efforts concerning this issue !
Posted on Jan 28, 2009
  • 100 Answers
SOURCE: Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Posted on Jun 04, 2009
dave1645
  • 834 Answers
SOURCE: 2 years old sharp aquos
sorry to say , your LCD panel is failing , and you will need a new one cost is about 1500 unless you can find a used one on shop jimmy.com
Posted on Nov 28, 2009
SOURCE: remote sensor on Sharp LC37D44U not working
I have same issue. I see there is a replacement IR board that is covered (i think) for me under 3 yr parts warranty. If you are out of warranty, i found it online for 19$ 8)
http://www.discount-merchant.com/SHARP-NE264WJ-IR-Remote-Control-Sensor-Board-p/1157614.htm
Posted on Jan 11, 2011
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Sharp Aquos LC-C4654U The TV blacks out frequently. The blackouts last aprox. 1-2 sec and when the picture reappears, the blue box appears in the top right corner (just like when the tv is initially...
Good day!!! That problem is cause of faulty capacitors on the power supply... just look at the actual image of it through visual check if the capacitors look like leak/bulged on top you need to replace it to end that problem... hope it helps... \thanks for using fixya..
Sep 13, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
I have a Sharp 52in model LC52D62U.The (on) light blinks on an off 2 time an the (opc) light blinks on an off 5 times. Can you tell me what this code meanes. If that is a code.I can not turn the TV on. IT...
yes , the problem on ur tv is the main signal board , when this board goes bad the opc light blinks , i have fix like 20 tv with this problem , now to order the right board u most look at tuner inside ur tv and get a 4 digic number follow by word main , by replacing this board would fix this problem on ur tv
Dec 15, 2010 | Sharp LC-52D62U 52 in. LCD HDTV
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Sharp Aquos 32 nch TV, turn TV on, come on & goes off withn 2 sec
You have an intermittent power supply issue. See if you can get a used one on the cheap.
Aug 23, 2017 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Samsung tv won't turn on
do u hav e back light , if u do u may have a bad signal board ,need model #
Nov 07, 2008 | Televison & Video
Sharp Aquos HDTV LC52D62U Caption Not Readable
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go
  5. then at the same time press “Vol –“ and “Ch. Down”, you should see the service menu appear (if it does not appear, try pressing the two buttons again, it needs to be exactly at the same time)
  6. Then use the “Ch. Down” button to navigate down the service menu until you see “Industry Init” (NOT Industry Init +cause)
  7. Then press “Vol +” to toggle it to “ON”
  8. Then “/////////////////” should appear.
  9. when the screen turns GREEN, unplug the TV. Wait about 30 seconds, then plug the TV back in.
  10. Then continue on with the initial setup again.
This puts the TV back into the “fresh out of the box” settings. See if this helps with your CC problem.
Mar 15, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp TV switches to "input 2"
There's an option on the menu to tuen 'demo mode' on and off. If it's set to on, that's your problem. It will be switching input sources every 2 minutes or so. Switch this off and it'll be ok again.
Feb 13, 2008 | Dual XDVD8181 Car Video Player
Sharp LC-52D62U 52 in. LCD HDTV Logo
85 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
