Question about Magic Chef Dryers
My dryer is suddenly not very hot, there is heat, but not near as hot as it usually is
  • Magic Chef Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
My Hoover vhv680c tumble dryer is working but does not get hot I have changed the element but still no good
There are other possibilities. Dryers have one or more temperature sensors that will open circuit the heater element if they get too hot. If the sensor goes bad you get no heat. These are usually located near the end of the heater element. Find the wiring diagram and you will see them. With the dryer unplugged you should be able to measure almost no resistance across their terminals. Another possibillity is in the timer. The contacts inside of it could be bad. This is likely if you get heat on some cycles and not others.
Dec 07, 2014 | Hoover Dryers
Dryer will heat when put on 70 minute cycle but will not heat total time. if you put it on 20 minute cycle will not heat at all.
Hi, Some dryers have a cooling cycle that lasts for 20 minutes to cool the drum and its contents so you don't burn yourself when getting clothes out.
alot of machine have a max drying time of 120 minutes 20 of that will be for cooling so 100 mins hot!
the cooling cycle is usually indicated near the end of the dial in a different colour to that of the hot cycle.
Hope this helps.
Feb 11, 2011 | Dryers
My gas dryer all of a sudden just stopped getting hot. it runs but just does not get hot.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 02, 2010 | Whirlpool WGD5600S Dryer
My kenmore gas dryer model 65761 stopped heating up, any suggestions?
I would suggest checking the hot surface ignitor. This is what lights the burner to give the machine the heat. It is usually located at the lower rear right side near the burner tube and glows red hot when the dryer is turned on. It usually has two white wires going to a plugg and held in by a couple of screws fairly simple to replace once you get to it. Probably have to take the front of the dryer off to get to it.
Jan 19, 2010 | Dryers
Dryer smells hot and back panel near heating
your duct is clogged or the limit snapstat is not working. turn dryer on and go outside to the duct vent , their should be a minimum temp of 10 degrees, and a maximum 15 degrees outside. also sometimes just cleaning the lint from inside the dryer, can cause this smell for no more than 5 minutes. thanks karl
Dec 15, 2009 | GE DBXR453EV Dryer
The dryer runs but no heat
Check for a blown thermal fuse or a faulty heating element. Both components should be located inside the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty component. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 03, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Dryer does not get hot
Check for a blown thermal fuse or a faulty heating element. The thermal fuse is about an inch long and is located just inside the rear of the dryer and is usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. The heating element can be tested in the same manner. Sure hope this helped and best wishes.
Aug 28, 2009 | KitchenAid Dryers
I just bought a new heating element for a 70 series dryer and it is still not getting hot. What is another possible solution
test the hot side of the heater element, also check that the circuit breaker has been turned all the way off then all the way back on. If this does not fix it or you have tried it let me know and I can tell you what to check next.
Aug 20, 2009 | Dryers
Clothes dryer not getting hot enough to dry in a good time frame
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Oct 03, 2007 | LG DLE0332 Gas Dryer
pleas4e help my dryer is working but it won't get hot it just blows cold air please help me fix this problem
Jul 20, 2007 | LG DLE0332 Gas Dryer
Dryers Logo
49 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Charles T Nevin
Charles T Nevin
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
