SOURCE: backlight doesn't work
Go to this link; http://world.casio.com/wat/download/en/manual/ and enter the four digit code on the back of the watch, you should get a user manual - i do think you are probably right however. Hope this helps :)
SOURCE: looking for instructions for a seiko digital alarm
http://www.seikowatches.com/support/ib/index.html
There are so many aplications use of the manual will be manditory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
seiko chronograph set the alarm etc
pull the crown out 2 clicks....
set the alarm the same as your current time on your watch.....
push the crown in 2 clicks.....
than pull the crown out 1 click .....
set the alarm at the desired time with the lower button.....
than push the crown in 1 click ....
the alarm is ON
or go to this address
http://caliber.seikowatches.com/
select the desired language
than - alarm chronograph
and play the alarm option on your right
Replace the battery, the solar part doesn't mean it charges from the sun it has to do with the movement of the arms (I'm not %100 what that means) I just know it doesn't charge by the sun or any other light source.
