Question about Canon iRC3100 Printer
Fehlermeldung Canon Ir 3100cn E 000602-0202 geht nicht weg. Bitte um Hilfe
SOURCE: Canon iR 3100CN copier
its hard drive problem so change it
Posted on Sep 10, 2008
  • 37 Answers
SOURCE: showing error code E000020-01a9 on IR 3100CN
this code is for the density of the yellow toner, most likley has a bad drum.
Posted on Aug 26, 2009
canontech
  • 1219 Answers
SOURCE: Canon iR 3100 CN Fehlercode 000602-0202
Hdd error - call service!!!!
But if you want do something on your own:
A:1) Make the following selections, and enter '1': COPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HDCHECK*.
3) When done, turn off and then on the main power.
B:
1) Find the appropriate CHK-TYPE from the table 'HDD Format' ; then, make the followingselections, and type: COPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CLEAR.
C:
1)** Start up the machine in normal mode (i.e., turn on the main power while pressing the 1 and 7 keys ; then, make the following selections, and press the OK key:
COPIER>FUNCTION>SYSTEM>DOWNLOAD).
2) Perform formatting of DOSDEV4 using the Service Support Tool.
D:
1) Replace the main controller (main) board.
2) Remove the image memory (SDRAM) and the boot ROM from the previous board, and attach them on the new board.
E:
1)** Start up the machine in safe mode (i.e., turn on the power while pressing the 2 and 8 keys).
2) Format the HDD (ALL) using the Service Support Tool, and download the system software (SYSTEM, LANG, RUI).
F:
1)** Replace the HDD, and start up the machine in safe mode (i.e., turn on the main power while pressing the 2 and 8 keys).
G:1) Make the following selections, and enter '1': COPIER>FUNCTION>SYSTEM>CHK-TYPE.
H:
1) Turn off the main power; then, turn on the main power while pressing the 1 and 9 keys (so that the machine will automatically start its remedial program*, turning
the control panel solid black).
2) When done (i.e., when the control panel turns white), turn off and then on the main power.
If the machine does not run its remedial program in response to the foregoing step, go to E.
I:
1) Find the appropriate CHK-TYPE in the table "HDD Format"; then, make the following selections and enter CHK-TYPE.
2) Make the selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CHECK*.
J:
1) Make the following selections, and enter '4': OPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CHECK (1 to 5 min).
* Takes about 30 to 50 min.
** As necessary, ask the user to use the RUI to collect address book data, transfer settings, and user mode settings.
Posted on Jun 16, 2010
canontech
  • 1219 Answers
SOURCE: Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
canontech
  • 1219 Answers
SOURCE: Canon iR 3100CN Error code E000732-0001
E732 Reader communication error
0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the
reader power supply
Hope that helped!
Posted on Jul 25, 2010
I need drivers
Sehr geehrte Damen und Herren,
ich bitte Sie um Hilfe für einen Treiber für meinen Mini-DV-Panasonic-Camcorder NV-GS17
(24 x optical zoom)-weil ich sonst keine DV-Inhalte auf den PC übertragen kann,-weil der
o.a.Camcorder nicht vom System erkannt wird!Eine Verknüpfung wird nicht anerkannt!?
Oder gibt es eine andere Lösung für mein Problem???
Ich danke Ihnen sehr für Ihre Hilfe,-mit freundlichem Gruss......Helmut Scholz
P.S.:Mein System ist:Windows 7-64 Bit/ DANKE !
Aug 12, 2011 | Panasonic NV-GS17 Mini DV Digital...
Das gerät sharp al 1252 arbeitet nicht mehr. im display erscheint h und 4 abwechselnd blinkend. bitte um hilfe. danke.
The error code H4 means that you have a problem with the fuser unit. It is not warming up correctly. Also, the problem maybe that you may have had a power surge.
Sep 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Oxc19a0023
Click on this link, maybe it will help solve your problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&cc=us&lc=en&dlc=en&product=3396080
Apr 01, 2010 | HP Photosmart D5460 InkJet Printer
Hallo ich brauche euere hilfe seit 3 tagen komme
Das ist ein Problem mit der Facebook-Website. Der einzige Weg, es zu beheben ist, indem Sie die Support-Team und lassen Sie sie wissen, der das Problem gelöst. Wir hier bei Fixya müssen nicht die Mittel, um dieses Problem für Sie lösen. Danke.
Dec 07, 2009 | Facebook Social Network
Akku l??d nicht.
Setzen Sie die Batterie innen richtig und versuchen noch einmal. Rob
Feb 21, 2009 | JVC Everio GZ-MG21 Camcorder
Sony walkman atrac ad
hilfe mein player zeigt mir immer keine datenbank gefunden bitte um schnelle hilfe kann ohne das dingen nicht mehr DANKE
Sep 30, 2008 | Sony NW-HD5 MP3 Player
Laptop MSI bleibt Disktop schwartz
dai ammachen punda mathiriyada type seiurathu.
sunni naye.
Jun 05, 2008 | Computers & Internet
Canon iRC3100 Printer Logo
59 people viewed this question
old marine
old marine
