Question about Kenmore 44102 Front Load Washer
Pump is buzzing and water wont pump out - Kenmore 44102 Front Load Washer
  • Kenmore Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Nov 07, 2010
My washer wont spin,
If you had to empty the water manually, i.e the outlet pump did not drain the water out then I would suggest the pump is either blocked or has failed. This will normally prevent the spin cycle from occurring. Try checking and cleaning the pump filter out.
Dec 31, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a Kenmore 600 washermachine it won't spin or rinse. It would fill up with water and go all the way through the cycle until it got to the last rinse cycle and just stop and make a buzzing noise...
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
p.s the buzzing noise is the water pump humming because it can not spin the problem is definitly your water pump have it repplaced and it will work fine
please take the time to rank my reply if your happy with it.
Dec 01, 2010 | Kenmore Washing Machines
We had to replace our hot water tank, we did this
try opening the bleeders on your radiators,one at a time starting at the one closest to the pump until all air has been expelled then close bleeder and move on to the radiator next furthest from the pump and so on.if hot water doesn't come out from the first radiator within a short time, or if you cannot hear air being forced out thru bleeder you prolly have a defective pump; have it checked/replaced by a reputable pro..my guess is that the "buzzing noise" is because the pump is defective and the electricity has no place to go.an easy preliminary check for this is to feel the pump motor while buzzing to see if it is hot, if ti is it prolly is bad
Nov 14, 2009 | Plumbing
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
Water wont spin out but hear buzzing sound
The water pump is spinning but not pumping it out change the water pump.
May 12, 2009 | Washing Machines
My washer wont spin out
kinked hose or blockage in the water pump you defininatley have material in the water pump
disconnect washer all together pull out after you drain the water by hand as far as can go use a dolly take out side drain the rest by tipping on side you might need 2 or 3 people to get the washer out with little water left when on side pull the water pump off look inside and pull material out with a pair of needle nose pliars that clamp you will need 2 people to pull out material one to hold the pump and one to pull material out with pliars
once done before you put back together do a lube on your washer with appliance oil this will insure good maintenance
what i decribed at top is the non costly way to fix your own washer if there is material stuck in water pump
Jun 13, 2008 | Maytag Washing Machines
Kenmore 44102 Front Load Washer Logo
71 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
