Question about Rockford Fosgate RFX-9200 CD Player
I am having trouble with my display lighting. Sometimes the display is bright and sometimes it's dim. The TFX 9200 is installed in a 2006 Chevy Silverado 1500 with the automatic lights. I was wondering if can connect the dimmer wire to 12v swiched source so the display will be bright all the time
  • 3,083 Answers
To clarify, are you talking about your general dash lights, or a varying light level on the player?
If it's the dashboard lights, you could bypass the potentiomer by probably disconnecting one wire and joining it to the output. If the player display is controlled internally, in the player, you would have to open it and physically bypass the control circuit, but chances are that it's a ribbon connector inside the player, or possibly a bad solder connection that merely needs to be reflowed.
I would think your idea about rerouting the dimmer wire would work, though I've never tried it, or known anyone who has.
Wish I had a definitive answer, but hope this helps.
Posted on Nov 07, 2010
Drivers side turn signal blinking fast other side normal, bulb change didn't help
Even after bulb change, do all lamps work? Bad ground can be shown by weak or dim bulb sometimes and this can cause fast flashing. All bulbs which flash must be working and of normal brightness which is sometimes hard to tell when they blink really fast.
Feb 27, 2015 | 2006 Lincoln Town Car
Holosight dim in bright sunlight
I would send it to them to be checked.
Bushnell
Attn repair
9200 cody
overland park KS 66214
make sure to put your name, address, telephone number, and a detailed description of the issue in the package.
Feb 13, 2013 | Bushnell ® HOLOsight
Why will my dim lights on my 2006 chevy trailblazer not work only the bright
Your low beam relay might be bad or the dimmer switch is faulty. A possible cut/corroded wire could also be to blame.
Jan 13, 2013 | 2006 Chevrolet Trailblazer
While driving Down the road sometimes the lights would turn off while switching from brights to dims and now we no longer have no dims at all just brights.
I had a similar problem with my 2002 chevy impala, it was the BCM Module, Costed about $680 to replace it from the dealership, the Dealership has a special tool to replace the old BCM because it has your car information and it has to be put on the new BCM.
Dec 04, 2011 | 2002 Chevrolet Impala
Our 2001 dodge gr caravan has trouble with frt
any time you see a dim headlight it is caused by a loose,or missing,or dirty ground to that light.
Jan 05, 2010 | 2001 Dodge Grand Caravan
Laptop display light not working
It may be the inverter whick is a small board located at the bottom of the LCD panel and plugs into the backlight. Usually you can get them off of eBay for less than $20
Hope this helps
Apr 25, 2009 | Dell Inspiron 9200 Notebook
The screen on my Apple Powerbook G4 goes dim and sometimes out.
How long before it goes dim?
Does it start strong, then dims right away?
Feb 27, 2009 | Apple iMac G4 Desktop
Lights go out
Dimmer switch is going bad. If you rapid fire the switch they will switch from bright to dim or dim to bright. replace the colum switch.
Feb 08, 2009 | 2001 Dodge Ram 3500 Truck
Rockford Fosgate RFX-9200 CD Player Logo
79 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
