Question about Candy Washing Machines
Need instruction manual for candy front load washing maching mdl. C1658xt
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Posted on Nov 20, 2008
  • 1075 Answers
SOURCE: Hi, I have Front loading
simply go back to the shop it was bought in and they have to supply with the instructions in english at your request at no further charge,email bosh at there customer services they will gladly supply you free of charg.adrian
Posted on Feb 15, 2009
  • 11 Answers
SOURCE: circuit board on candy washing machine
you must specif the model of the machine and getme more information
Posted on May 12, 2009
  • 197 Answers
SOURCE: My Candy GrandO washing machine is boil washing
sounds like overheating, don't use until you have had it checked, may be dangerous
Posted on Sep 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: Getting error code F1 and don't know what it
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Manual lost i need a new one please
http://service.candy-domestic.co.uk/manuals/Manuals.aspx?Section=11
Key in your model number and download the manual..
Jun 13, 2010 | Candy CN146 Front Load Washer
Candy aqua 10t user settings
http://service.candy-domestic.co.uk/manuals/pdfs/AQUA%201000T.pdf
I have found you a user manual, to download and read, this should help you resolve your issue.
Jun 03, 2010 | Candy AQUA1000T Front Load
I cant get the dryer to work as I dont know what buttons you need to use to get the dryer started
If you go the the following site, you should be able to find the user instructions for your model wsher dryer.
In the search box enter >>>
SERVICE.CANDY-DOMESTIC.CO.UK/MANUALS.
Then click on>>Laundry
Then click on>>Washer dryers
Enter the model number, and get the instructions.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Candy CNW156 Front Load Washer / Dryer
Need a User Manual for Candy CMD146 Type LCE2
Hello.
I can direct you to the site you need to download a copy of user instructions for your washer dryer.
In your browser bar, type -
hoover user manuals
In the drop down list, click on-
hoover after sales service-instruction manuals
Then click on -------laundry
then click on --------washer dryers
In the box enter your model, and you can download the instructions.
Pleas a fixya rating for my solution to your query..
Thankyou.
Jan 30, 2009 | Candy CNW156 Front Load Washer / Dryer
Instruction manual
Greetings psbrodie,
You can find a copy of your instruction manual at the following link http://service.candy-domestic.co.uk/manuals/Manuals.aspx?Section=10
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jul 01, 2008 | Candy CNW136 Front Load Washer/Dryer
Candy Activa Smart 1300 AA
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 25, 2008 | Candy AQ130 Front Load Washer
Wash cycle
remind me cycle 4 is m8 and ill try to help u candy are exactly the same as hoover and i have all data sheets for most hoover washers
Aug 28, 2006 | Candy AQ130 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
