Question about LG VX5500 Cell Phone
So what happened was that i was walking outside and my phone came out of my sweeter on to the floorbut the ground wasnt dirty or wet. (the phone had already fell once that day) i picked it up and looked at it from screen and it wirked fine. i got home and opened it but the screen was all white. but the front sceen was normal. so i closed it then i opened it again and the sceen was normal but then in a minute it turned all white again.I closed it and upened it then the screen appered upside down an evertime i pressed a botton it got fizzy (the colore). i charged it, then after it was fully charged i took out the battery and left it alone for a day. But the next day it was still all white. how do i fix this?
Take it apart and check your flex cable connection, see you tube video for taking your phone apart, easy fix if you have a small screwdriver. Takes about 15 minutes.
Posted on Nov 22, 2010
Phone got wet and phone shows red battary and yellow cation sign
hey the rice trick does sometimes work ya know , google the wet phone to see the rice trick
Jan 22, 2016 | Cell Phones
How do i fix a rough running after warming up in wet weather
I don't really know the answer, however, I would like to share my story with you, in case this happens to be the case with you. My older Volvo had all kinds of problems but only when warm and when it was wet outside. I had a mechanic that was throwing parts at it until my dad told me to go to an electrical specialist. He found out that the ground to the chasis of the car was not good, and in fact, when it was hot, it actually got red hot. The water aggravates electrical shorts. A bad ground is more common than most people think.
I hope that helps.
Apr 25, 2015 | Cars & Trucks
1997 Lexus LS400 wiring problems when it's wet outside
Insure the drive belt is turning the alternator properly. When it is wet outside the belt will slip quite a bit more if it is not tensioned properly. Also ....the ground from the battery post to the engine block needs to be checked to insure a great connection. Any resistance in the ground cable OR the positive cable from the alternator to the positive post of the battery will cause your issue....dampness will make these issues worse.
Would check output of alternator when damp/wet outside...and find a tech that KNOWS how to perform a voltage drop test on the battery cables and the alternator output wire that goes back to the battery.
Hope this helps!
Scott, Porsche Master Tech. 35 years
Jan 12, 2014 | Cars & Trucks
Installing sprinkler timer
GFCI is just a protected plug for use in wet areas - like Te one in your bathroom. Your sprinklers will work fine plugged into a regular outlet but it may void your warranty if something happens. If your timer is outside or not well protected from weather then consider installing one of these outlets. 7_11_2013_1_40_33_pm.png
Jun 22, 2013 | Garden
When I walk inside my work building my cell phone doesn't accept calls, make calls, texts & internet isn't working. But when I walk back outside, it starts working again. Please help.
This building is preventing cell phone signals from reaching your phone. Try using your cell next to a window where signal are not obstructed by reinforced concrete walls.
Feb 15, 2012 | Motorola Cell Phones
I have 2 gfi outdoor outlet with orange lights on and cannot reset
GFCI is designed to detect ground faults, and will not reset if ground fault is detected, or if device is bad.
Seems odd that both GFCIs will not reset unless both are outside.
If GFCI is outside, they get dirty and wet, and the GFCI goes bad.
If GFCI will not reset, open following links:
http://waterheatertimer.org/pdf/GFCI-outlet-will-not-reset.pdf
http://waterheatertimer.org/How-to-wire-GFCI.html
Jun 18, 2011 | Leviton 8599 GFCI Receptacle
Fuel leaking almost poring from under back left seat, under car
If the location of the wet spot was towards the rear of the car by the fuel full hose and as you said the leak stopped as you use up fuel and lowered the fuel level in the tank than the leak is located in the fill pipe area or tank. Next time you fill go under the car and look for the wet spot.
May 11, 2009 | 2002 Volvo V70
Phone won't turn on
Try putting the sim card in so it clicks, i had this problem TODAY, :)
Aug 06, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
Cracked screen- need help!
Not really much of a solution for a cracked LCD (that's what you're dealing with) outside of a new phone or a new LCD. If you left it on the ground, it either took a hit, or got too hot (southern US would get plenty hot enough to do this). Sorry, but you may want to start saving up for an insurance claim.
Jun 16, 2008 | Cell Phones
LG VX5500 Cell Phone Logo
211 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
