Question about Bazooka Car Audio & Video
Bazooka amp amp will not come back on red light stays on
  • 631 Answers
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it remains in protect mode, the amp almost certainly has shorted output transistors and will need to be repaired.
Posted on Jun 15, 2008
Audiopipe amp 1000w on 2 8" double ended bazooka
You may be over driving the speakers or there may be an impedance mismatch between the amplifier and speakers, especially if they are connected in parallel
Nov 12, 2012 | Car Audio & Video
Hey i dont know to much about amps, but me and my friend (he knows a decent amount about amps) would plug the power into the amp and the green light would come on. Though when we plug it into the subs, the...
Are you connecting positive to positive and negative to negative from the sub to the amp? If so, try positive to positve (+) in the far left channel and then the negative to negative (-) on the far left channel to. If no luck do the same in the other channel with one sub at a time. Try one sub at a time, Dont try an connect 2 or more subs to one channel as this would cause the amp to go into protect mode (red light you describe). Usually the positive wire has either a line down the wire, writting on it or has a red seperate wire with it when wire end stripped to connect it. Hope this helps and please rate...
Mar 11, 2011 | Bazooka EL1500 Car Audio Amplifier
A red light appears within 30 sec. of being on. the more i tune it down the longer the green light will stay on. when its completely tuned down the light will stay green
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 21, 2010 | Bazooka EL1500 Car Audio Amplifier
I want bass that can pound
What kind of speakers are they? Liquid cooled speakers? I am assuming you are working with the bazooka speakers? Honest sugguestion: get different speakers. Bazooka is not that good of a brand. looking at bazooks's webiste the magnet size is only 30 ounces! The only good thing I have seen that have come out of bazooka was way back in the day their "P. Miller" series (a.k.a. Master P) And I never tested the subs, only the amp. What kind of car are you putting them in?
Next, a 4 channel amp is usually designated for the midrange/tweeter speakers. If you want good hard bass, only a mono or duel channel amp will put out the ohms that you need. Remember, you get what you pay for. If you get 20 dollar speakers and a 50 dollar amp, do NOT expect to hang with the big boys, even if the speaker is a 30 inch and the amp claims to be a 10,000 watt. Stay away from sony, stay away from bazooka, stay away from unknown brands.
My ideal set up would be Alpine type R or type X for subs, a Fosgate or memphis amp, and mb quart mid/tweeters. All are readily available, so competition keeps the prices affordable. Look at magnet weight when choosing subs.
Oct 01, 2009 | Car Audio & Video
My protection mode red light comes on right when i put the fuse in my power line, even when my cars off!!! is it that my ground is bad? ineed some help!! oh ya, lol, its a ela300.1 bazooka amp!
Check your ground most definitly!, Replace it if needed. Check your remote wire and power wire as well. And if none of this works, then you are having internal issues.
Aug 26, 2009 | Bazooka ELA300.1 Car Audio Amplifier
Csa300.1 bazooka 500 watts
sounds like you may have blown your sub...sheck the spyder inside of it and see if it is stiff..if the speaker doesnt seem too responsive when you press on it, its probably blown...
Aug 01, 2009 | Bazooka ELA300.1 Car Audio Amplifier
Red Led Light on My Bazooka Ela300.1
Your amp went into a " Protection Mode "
this happens if you have blown something inside like a IC or something... if the amp have been dropped or bumped then its very likely to happen ... Check and see if your fuses are ok, if not then it would be best to let it be checked by a expert if its a IC or a cap inside
Dec 18, 2007 | Bazooka ELA300.1 Car Audio Amplifier
Car Audio & Video Logo
488 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
