Question about Ovens
Whata does WM oven temperature means - Ovens
I have a Whirlpool drop in stove. I had food in the oven baking and all of a sudden the timer started going off. F-1 was displayed on the front of the stove. Can you tell mean what F-1 means?
F1 - Control Board Failure - Replace control board (clock).
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ...
F3 - Open Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
F4 - Shorted Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
Whirlpool Google Search
Dec 15, 2016 | Whirlpool Ovens
On a whirlpool double oven, what does F2 error mean
F1 - Control Board Failure - Replace control board (clock). F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ... F3 - Open Oven Temperature Sensor Replace oven temperature sensor ( ). F4 - Shorted Oven Temperature Sensor ( - Replace oven temperature sensor
Nov 23, 2016 | Whirlpool Ovens
F-2 and F-3 codes keep blinking and ther is a loud beeping sound ,usually when oven is heating up and after oven is heated up and when oven is cooling. occasionaly it happens on a cold oven thanks
Hi, F2 and F3 means Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Jan 04, 2011 | Fisher and Paykel AeroTech Double OD302...
What does f2 mean on the oven
Hi mil4kids,
F2 means the oven temperature is too hot. The easiest way to correct this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Thank you for using FixYa.
Dec 20, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
What does f-4 mean
The F3 or F4 means Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 25, 2010 | Magic Chef Ovens
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
I haVE A MODEL NO 47465 WHEN OVEN IS ON AFTER 3 MIN THE CODE F_2 COMES ON
This means that the oven temperature sensor is open. Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor.
Click on this link to see how to check the sensor temperature.
Thank you for using Fixya. Your generous rating will be much appreciated.
Oct 13, 2010 | Kenmore Ovens
What does an F3 trouble code mean? We were using the self-cleaning feature when this came on. We were cleaning it because we thought it might help the thermostat, which has been keeping the oven running...
Hi, F3 code means Shorted or open oven temperature sensor (RTD)
Solution Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 10, 2010 | Maytag Ovens
What does e1 f3 fault code on my oven mean
F3 means your oven temperature sensor is open. you will need to get it replaced. hope this helps.
Oct 15, 2009 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
862 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
