Question about Minolta Maxxum 7000 35mm SLR Camera
Maxxum 7000 Camera is seemingly operational but the shutter is apparently not working properly as most of the shots are either half or no image. The camera was supposedly repaired by Minolta on two occasions in the mid 90's to little avail as it seems. My question is whether repairing the 7000 is cost effective even though it is one of the first mfg. batches with the crossed xx logo.
    Scholar:
  • 185 Answers
Photolou,
if you can find a camera repair shop to fix it reasonably i would. however there are no new parts available so any replacement parts will have to be good used. be sure they warranty their work.
Posted on Dec 10, 2008
Minolta maxxum 7000 flashing display
Shutter prob jammed and needs to be re-lubed, Common problem with this mode. Comes from lack of use.l
Apr 30, 2014 | Minolta Maxxum 7000 35mm SLR Camera
Dark, cloudy viewing 35-135mm Sigma lens
The problem sounds like the camera did not reset properly after the last exposure. Minolta deigned the camera to keep the aperture fully open except during exposure.
During exposure it snaps the aperture down to the selected opening, then opens it again to allow enough light for proper focusing. If it did not fully open the blades after the shot, much less light would pass through the lens. The viewfinder would be darker and look murky.
Most likely cause? Dried up lubricants in the camera.
Next likely cause? Teeth broken on a plastic gear.
Get it to a camera repair place. Get estimates first.
Dec 30, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Is the Minolta Maxxum 7000 capable of using infrared film?
goneoutthewi,
once the shutter is closed or the shutter open and the mirror is up no light strikes the film except the image. don't forget to use the red markings on the lens as infra-red focuses on a different plane than visible light.
Mar 27, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Lens compatability
Most lenses used on your Maxxum should work with the Sony digital SLRs - some features of the Sony won't be available, like image stabilization, but for general photos you won't notice.
Jan 04, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 5000
I had the same problem with a maxxum 7000. Traced it to a bit of corrosion in the battery pack. It let just enough power through to run the computer, but upon releasing the shutter, it shut off.
You might check that. corrosion can be cleaned with vinegar.
-John
Oct 07, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta MAXXUM 3xi the view finder is very dark(bought second hand)
I no the older Minolta's had an aperture problem the pictures when zooming out after they were developed were very dark. But inside and wide angel shots always came out nice I had to have the aperture base plate replaced on my Minolta Maxxum 3000i my point and shooter, I wish this helped but it sounds like something different in your case it also maybe the aperture acting different in your camera than it did in 1 of mines.
Jul 27, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Shutter blades out on Minolta Maxxum 7000
It is possible to fit them back since they are flexible. It does require a gentle touch, with a lot of patience. I use angled tweezers for this task.
Replacement parts are no longer available. Used cameras can be found on ebay and the like.
Feb 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta maxxum 7000 35 mm camera
I had the same problem. After I replaced the lithium backup battery, everything works perfectly. It is a CR2016 watch battery and it is located behind the silover plate inside the battery compartment. Remove the 6 screws and replace the battery. Note the polarity when you remove the plate because the camera will not operate if if it is put in backwards.
H
Nov 14, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Lower half of photos dadrk when printed
Set camera to B , open back door and release the shutter and keep it open while you inspect focal plain area. Is the shutter fully opened ? If you release again is the shutter opening completely and closing completely ? While the shutter is fully opened on B look through the shutter/ mirror box area is anything obstracting your view ? Seems like one of the shutter curtains is not opening properly and shutter will need servicing. Please note that it may not be economical to repair : $ 150-200 if the shutter block does not have to be replaced completely.
Apr 22, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
