Question about Philips Audio Players & Recorders
I recently moved and am having trouble getting my phillips subwoofer system model : MMS171W hooked up properly There is a loud background hum when I attach it like I think it should be attached. Any ideas ?
    President:
  • 547 Answers
This is most likely a "ground loop" and is caused by using two different electrical outlets for the two parts of the system -- main receiver and subwoofer amp.
Try using the same electrical circuit (wall outlet) for all of the equipment in the home theater, using a power strip or strips as needed.
Posted on Nov 07, 2010
  • idive4fun Nov 07, 2010
    Iam using a power strip and will change plugs around and play some more.
  • Rob C Nov 07, 2010
    Ok, if you're on the same power then the next thing to check is the audio hookups. How do you have it hooked up now? (what's the label on the connector on the subwoofer side, and where are you connecting it to the rest of the system)
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
I own a Bose Acoustimass 7. I noticed humming coming from bass more noticeable than before (although I recently moved it to another smaller room) I also noticed when I hear this humming- the higher I turn...
I was having this very same problem. I finally figured out that I was getting feedback to the system because my TV cable coming into the house wasn't grounded right.
Oct 04, 2011 | Bose Acoustimass 15 System
Have an older (6 + Yrs) VX-10A model, that's worked fine up until now. I recently moved, hooked up the same stereo and surround sound speakers, which worked fine, but the subwoofer made a loud hum as...
Disconnect the input and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 03, 2011 | Velodyne VX-10 Subwoofer
I need drivers for philips subwoofer mms171w
Subwoofers are only speakers! You do not need drivers for speakers or woofers. You only need drivers for you sound/audio card/device. Probably you need the audio/sound software to configure the sound system for the "subwoofer and its satellite speakers.
Oct 23, 2010 | Computers & Internet
Loud hHum from Subwoofer
Sounds like the hum might be mains hum caused by the failure of the power supply capacitor(s) in the sub. It/they will be the largest on the pc board. You will find all the details (needed to replace it) on them. If you find more than one replace both.
Dec 10, 2009 | Audio Players & Recorders
Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Jun 28, 2009 | Bose Companion 3 Series II Multimedia...
Loud humming sound from subwoofer
just try leaving it unplugged for a while thats what i did and it fixed it
Sep 21, 2008 | KLH PSW8100-8 Subwoofer
Hum in subwoofer
If you have cables hooked up and have not installed them to the components when turned on the speaker will hum.
If your electrical outlet is not grounded properly you speaker will hum.
Personally I'd take it back and get a new one. if you just purchased it.
If this happens again try a grounded curcit first then go from there.
Oct 22, 2007 | Jensen JHT525 System
Loud humming coming from subwoofer
This can be caused due to an increase in local interference. The hum is decreased when you plug in the satellites because the interference is spread over a longer area. You may notice that speakers tend to hum around things like cell phones and power outlets. To see if this is the case, move the speakers to another part of the room if you can, slide the desk around, plug the computer in at another room, something like this. If the hum gets louder or quieter, it is interference at your new place. This can be solved by finding a new area to set up your computer stuff at. Since it's mostly the subwoofer, try elevating it off the ground, there may be a power main running under the floor.
Sep 04, 2007 | Audio Players & Recorders
188 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
