Question about Samsung RS2530BSH (25 cu ft) Side by Side Refrigerator
Our Freezer is working just fine, however our refrigeratoor is not getting cold. It is about 58 degrees, and no matter what we set the temperature controls at, it will not get cold.
  • Samsung Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 07, 2010
More than likely your fridge/freezer operates on 2 compressors/2systems. your fridge needs a re-gas and/or new door seals.
What could cause the fresh food section of my refrigerator to be too warm?
UR COLD CONTROL THERMOSTAT, UR AIR FLOW VENT, UR THERMISTORS, A EVAPORATOR FAN NOT WORKING OR OBSTRUCTED
Feb 24, 2015 | Refrigerators
Refrigerator will only get 58 degrees no colder, freezer is working fine, dial on fridge is on coldest setting...help
heatman101
Nov 28, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Amana BX518VW refrigerator not getting cold enough
Amana is not a S.African make, but all work on the same principle. What i think you have is an evaporator fan motor that is located in the freezer compartment that has jambed up with ice. The freezer needs to be defrosted to allow freezer panel/s to be removed to allow access to the evaporator.Check motor for free movement and if turning freely, switch fridge back on and try and determine if fan comes on. (open door periodically to inspect) If so, replace panel/s and retry. Not sure if you have an auger motor controlling the frost intake to the fridge but if you do, it could also cause problems. Check to see if it can move freelt.
May 20, 2010 | Refrigerators
Freezer not geting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Refrigerator will not stay cold. The top of refrigeratoor is hot
if freezer is working correctly then fan is probably not working fan blows cold air from freezer into the fridge.
Jul 12, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Samsung RS2530BSH (25 cu ft) Side by Side Refrigerator Logo
244 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
