Question about Garmin nuvi 200W GPS Receiver
Battery charging just got my garmin ,when i plug into cig lighter red light is on ,how do i know when it is fully charged?
  • Anonymous Jun 18, 2008
    even when charger is plugged in cig lighter and there is some charge screen will not come on.
    Problem Solver:
  • 8 Answers
Cig-lighter offers 1A current. The battrey will be fully charged for 4 hours if the unit is not used.
Posted on Jun 21, 2008
Iplug into cig lighter red light is on and still have some charge left but nothing comes on screen.
Posted on Jun 18, 2008
Garmin GTM 25 Charger is not charging GPS, but the red light is coming on when plug in to GPS and Cig lighter. Could this be a fuse in the charger?
Unscew the Cig lighter plug silver or black tip part, the fuse in located in there, be careful its sping loaded....check fuse should be a 3 A fuse any Radio Shack should have it or auto store
Sep 22, 2010 | Garmin GTM 12 FM TMC Traffic Receiver...
CHARGING MY GARMAN GPE C330. DO I LEAVE THE GARMAN ON OR OFF WHEN CHARGING . THE BATTERY WAS DEAD ON MY WAY BACK FROM MY LAST TRIP.IT WAS OK GOING UP I HAD IT PLUGGED IN TO CIG LIGHTER BUT GARMAN SEND...
Disconnect from cigar lighter and connect to the USB port of your computer or any AC adapter over night. By morning the battery will have recharged and be ready for use. This seems to happen with the GPS is left connected to a vehicle's cigar lighter for an extended period of time. You can do this USB / AC adapter recharge procedure as often as needed.
I hope this helps!
Jun 08, 2010 | Garmin nuvi 250W GPS Receiver
My garmin does not operate plugged in to my car nor by battery
You have not said why that is....
Have you fully charged the battery prior to using in the car?
Using the power from the 12v plug in a vehicle will not "charge" the internal battery, but tends to maintain it somewhat. If the fuse in the end of the 12v connector plug is blown and the battery in the unit is low then this will cause the unit to shut down or fail to fire up.
Please check both, the units battery level and the fuse in the cig lighter plug and the plug that connects the unit to the cig lighter outlet.
Now the second half of your statement:
Nor by my battery
It is either not charged ( AC charger) or it has reached the end of its life which if used correctly is about 2 years. If the life of battery is shortened , then it is by a common practice of misuse. This misuse is to have the unit plugged to the car 12v when staring the engine.
1) it damages the battery life
2) It can and does damage the SIIRF chip, which is responsible for connecting to the satellites
I suggest that if it does not charge over a 10 hours Max period to its full state, then replace the battery immediately to avoid damage to the electronics from battery leak.
Thanks for using FIXYA
Oct 29, 2009 | Garmin nuvi 205W GPS Receiver
Garmin shuts off after 15 seconds with a low battery indicator
you will have to connect it to a computer using the usb port. thats the only way to charge it once the battery gets real low. my unit did the same thing.
Apr 11, 2009 | Garmin StreetPilot c340 GPS Receiver
Charging a Garmin Nuvi 260W
Generally most batterys are left on the charger overnight, thats a good way to ensure a full charge, but as you will be using it in your car, it doesn't matter much as power is always available.
To ensure best possible battery life when you have a brand new battery, charge it fully and then drain it almost to 0% Draining most batterys into 0% will be harmfull instead of helpful, I assume the nuvi uses a Li-ion battery so draining it fully is not a good idea, drain it almost fully and then charge it fully.
And you are good to go, repeat the process if you leave the unit unused for a month or two for best battery life.
Thank you,
IwillFixIT!!
Nov 15, 2008 | Garmin StreetPilot c550 GPS Receiver
Can my Garmin 610T be used whilst charged in the car
Fully charge the device before using it...did you plug any sd cards into it?
Jul 03, 2008 | Garmin nuvi 350 GPS Receiver
Garmin 200w
Yes it can be charged on the computer, but the ac is the fastest with cig lighter second. They are much much faster ways to charge it. So it depends on how you charge it.
Apr 20, 2008 | Garmin Nuvi 660 GPS Receiver
Unit fails to maintain charge
You are correct, most GPS units use a lithium ion rechargable battery, typically they loose there ability to retain a charge after about a year or so depending on use, resulting in the unit having to be always plugged in.
You probably could replace the battery on your own if you could get one, (needs to be soldered into the mainboard) however GARMIN does not sell battery's to consumers, they state that a battery can only be replaced by a garmin service tech.
Check the link below for contact info for garmin.
https://buy.garmin.com/shop/shop.do?pID=290&tab=sp340
Hope this helps
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 660 GPS
1) tap "where to" then "go Home" an option should pop up to save your current location as home, or type in an address.
2) tap "where to", then select the option you desire.  You can choose address if you know the address or select an icon that matches the type of business that you are looking for. The unit will list the business in order starting with the closest one. Tap the business you want and it should calculate the best route.
3)The battery should be fully charged before you use it on battery only, but it's ok to plug the gps in and use it.
4) If you leave it plugged in it will not damage your battery and you will always have a full charge for when you need to carry it.
Oct 20, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin c340 gps freezes up
Avoid buying Garmin GPS. Their units have a non user replaceable battery that last about 2 years. After that, you have to send the unit to Garmin to replace the battery and be hit with at least $150 plus shipping. Possibly more if they need to fine tune something else. Look at other brands with easier battery replacement such as Sony, Navigon, etc. Garmin is a total rip off.
Sep 08, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
257 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
