Question about Acer Aspire 6920 Notebook PC
When I startup my laptop it goes straight to Arcade Deluxe how do I get back to windows
  • 345 Answers
Per these pages:
http://www.theacerguy.com/forum/topic/quit-acer-arcade-deluxe
http://www.theacerguy.com/forum/topic/acer-arcade-deluxe-loading-on-startup-cant-get-to-windows
This one even tells you how to disable it in windows start up.
http://www.cybertechhelp.com/forums/showthread.php?t=182345
it says to make sure "HOLD" button is not turned on when shuting laptop down otherwise it will do what yours is doing. They are also talking about going in to safe mode and taking it out of start up. Just read the posts and you might be able to get rid of it. The one i found was towards the bottom.
Good luck.
Posted on Nov 07, 2010
After an update to arcade deluxe, using it caused the pc to blue screen. i returned to a restore point, but now arcade deluxe will not run. Can anyone advise?
Hello.
From this point, remove (Add/Remove Programs) and reinstall Arcade Deluxe. Then, if it runs OK, create a restore point. Then, update Arcade Deluxe.
Hope this helps.
Jun 11, 2011 | Computers & Internet
The Acer Arcade Deluxe Webcam is not working, but the Acer Crystal Eye Webcam is still working fine. Please, how can I solve the problem with Arcade Webcam software? I believe it stops working after some...
You can do the following: Start your PC as an administrator > click Start or the Windows ball > Control Panel > Performance and Maintenance > System > Hardware > Device Manager > Scroll down to the device driver you wish to roll back > right-click on it and choose Properties > Click the Driver tab and then click Roll Back Driver. Note: Win7 ball > Control Panel > Device Manager. By rolling back the driver, your Arcade Deluxe Webcam should work like it used to.
Oct 15, 2010 | Acer Aspire 55421462 Notebook
I need the program acer arcade for my pc,
Here is a link to another page that has download links for acer arcade depending on the windows version you have running.
http://komku.blogspot.com/2008/05/download-acer-arcade-deluxe-for-windows.html
Oct 28, 2009 | Acer Aspire 5315 Notebook
My laptop has Acer Arcade Deluxe & appears not to work correctly
you must have selected random play. Just uncheck it and it shall be done.
Oct 02, 2009 | Computers & Internet
Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Aug 09, 2009 | Acer Aspire 6920 Notebook PC
Acer 6920g has gone onto acer arcade deluxe cinema .
I have had the same problem ... that happend to me when I press the arcade deluxe button on the blue gem controler on the left. when I tryed to run vista again it keeps going to the arcade deluxe system ...
the only solution for that case that works with me when I run the system recovery and installed fresh copy from the windows vista that came with my laptop ...
I hope that helps you in your case.
Feb 10, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5920 - Acer Arcade Deluxe Problem
in bios, locate windows vista and set it up to start automaticly , (default operating system)
Jan 13, 2009 | Acer Aspire 5920-6727 Notebook
In acer 5920, acer arcade installed, can not be started by hotkey
You configure the keys from the Acer Launch Manager. If you go to Start, All Programs,  Acer System you will find the manual telling you exactly how to configure it.
Dec 10, 2008 | Acer Aspire 5920-6727 Notebook
Where can i download acer arcade or acer arcade deluxe for my notebook
what is it?a support driver?you can download it in acer website by using correct searce engine and by inputing the correct model.
May 19, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 6920 Notebook PC Logo
229 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
