Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
CDMix 2 Fader Start does not work
Please advise when the fader start button is pressed on, neither the left side nor the right side begins to start, all else is well.
Thanks for your input if you have any.
Both decks must be on single play
regards
Posted on Sep 27, 2008
I can't get any sound to go through Mackie 1604-VLZ3. I've tested to insert sound to every channels and checked all button positions and nothing comes out from main output or the phones....
There is NO way to select channels to "Source"... The selections on this mixer are to send the channels to SOLO, Sub1-2 or Sub 3-4 and/or main L-R. You should have the bottom button for each channel punched down to L-R. NEVER connect ANYTHING other than an external effects unit to the INSERT jacks!!!! These jacks are combined output/input jacks with send and return on the same jack. Special insert cables are used for these. An external drum machine should be connected to a line input for one of the channels USING a TRS balanced cable. Page 28 of your user manual shows the block diagram and signal flow diagram. The trim control is the input gain control. Start with those say at 12 o'clock and advance the fader for the channel of interest...you should get signal at the main outs. MAKE SURE that the lines from the mixer to the amps are BALANCED TRS type cables... You cannot use unbalanced cables for this. The user manual explains balanced cables and what they look like. I just repaired one of these mixers that some foolish people plugged stuff into the MAIN INSERT jacks and blew out the driver that drives the MAIN insert which kills the input to the MAIN output drivers. There is one small chip between the AMAIN fader and the sub next to it and one has to remove every knob and take the unit all apart to get to it... It is a tiny surface mounted part the size of a matchhead with 8 leads... not for the faint of heart to repair. As a test of this part, you can plug a st of headphones into the RIGHT MAIN insert jack and drive audio into a channel... turn trim control up fully for the channel and the fader on full, and set the PAN control to 12 oclock and punch down the L-R button for that channel. You should hear the audio in ONLY the left ear... Now try the phones in the LEFT INSERT jack... you again should hear the audio in the left headphone only (these jacks are not stereo like the headphones). If you cannot hear anything, then likely somebody has blown that driver in your unit... It is painful and time consuming to repair this... there are hundreds of knobs to pull off and put back on... dozens of screws and cables and to get it all back together. Also make sure ALL of your interconnected equipment is powered from a SINGLE receptacle or power module. Read your user manual thoughroughly. You can get one online download if you need it.
Sep 10, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Use of the radio: i like more the music coming from the back of the car.
Thats controlled by the fader, you can adjust front to rear levels.
Balance is left or right.
Nov 24, 2009 | 2000 Chevrolet Blazer
How to use Audioline Pro DJ Multimedia Mixer M Dex 3.0
I have been recently using this Cd Dj deck at parties and have some general knowledge of the product, it has alot of potential. Is there anything in particular that you need help with? Or is it the general concept of using them.
Currently, i don't think there are that many websites that explain how to use the Cd decks, however i can provide you with some basic information. Most of the information here could be worked out by trial & error.
- Pitch control on the right of each cd deck can be slid up ( slows it down %) and slid down (speeding the track up %) i think the pitch control has a range of either +-10% or +-16%.
- Cue button, has the potential for Cue'ing or setting up the cd to instantly jump to the "cue'd" point with the press of this CUE button. This is done by either pressing play/pause button and rotating the jog wheel to a point of time in the track which automatically sets the cue point OR holding down the >> or << search button to find a spot within the track at a greater speed.
-Vinyl mode. Pressing this button will set the deck to the "vinyl mode" to simulate scratching or even backspins. pressing this button again will change the mode back.
- the Crossfader (or 'X' fader) button will select the left cd track if the x fader is all the way to the left and the right track if the x fader is all the way to right. having the X fader in the middle will play both tracks together.
- Low, Mid, High. These nobs on the middle section of the deck change the individual track by which it is corresponds. (Left side = left cd track, and vica versa) Low refers to the Bass of a track which can be essential for mixing two tracks and elminating excess bass noise. Mid refers to the drumming and even synth of a track, and changing this can result in some cool sounding effects. High refers to the 'high' frequencies of the track playing, such as snares, hi hats and possibly vocals. All these controls are crucial to understand in order to mix 2 songs together successfully. It's good to get a chance to muck around with these cointrols. The middle of each control resets the setting to normal or default.
- Channel fader. the two controls that slide up & down on both sides of the mixer on the deck. This is also referred to the volume setting. Useful for mixing seamlessly one track into another.
- Gain. This control at the top of the mixer refers to the volume level or 'gain' of the cd track that it corresponds to.
- Jog wheel. Serves 3 purposes. firstly it can be used whilst a song is playing to temporarily speed up or slow down the track to match with the song on the opposite side. secondly, whilst holding down the 'search' button, operates as a control to quickly find a spot in a song. and lastly when selecting "vinyl" mode, can simulate the reaction of a vinyl turntable. The scatch function, and backspin effect.
- The pitch button, is just another control to speed up or slow down a song temporarily whilst holding down the '+' or '-' button.
- Reverse button, for a certain amount of time will play the song on the left or right in reverse.
- Time. this button is essential to change the time selection on the cd deck, to either "Time elapsed", "Time remaining" and "total time remaining on the cd".
- the "tap" button, allows the user to physically "tap" the button in time with the song's beat, which calculates the Beats per Minute (Bpm) of that song. which is essential to work out the bpm of 1 track to mix the speed with that of the opposite deck.
- Cd/usb/sd, changes the mode of system reading. from CD to USB or SD card.
I really hope this general guide to using the Audioline ProDJ MDex3 has helped!
Peace. Marc.
Apr 03, 2009 | Music
Fader start
Hi Gary Milchar,
Have you set the player to start from fader http://www.numark.com/stuff/contentmgr/files/0/fc90d6fb8cfaeec3e6dbbe22202aabfb/file/cdn22s_refmanual.pdf? (page 12)  If so check that you have continuity across the mini jack with one end plugged into the mixer.
Happy hunting.
Jan 24, 2009 | Numark CDN95 2-Disc CD Player
Play and pause button does not work
More than likely the button switches are damaged and need to be replaced. The CDMix1 is a very bad unit, chock full of issues. We wont even bother working on these anymore. This includes the CDMix 2 and CDMIX 3.
You might have to contact Numark directly for repair assistance on this one - www.numark.com
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Nov 02, 2008 | Numark TTX1 Turntable
PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Aug 09, 2008 | Peavey 32fx USB 32 Channel Mixer
SLIDESHOW function
You can play the images in your camera on a TV or save them to videotape by connecting the camera with the bundled Audio/Video cable. Power up the camera in the PLAYBACK Mode, press the OK/MENU button to open the menu and using the arrow keys toggle up to begin the SLIDESHOW. You can even change the playback format in the MODE MENU. Press the OK/MENU button and using the right arrow key select the MODE MENU. Toggle down to SETUP, toggle right to enter the SETUP MENU and toggle up once to PLAYBACK SETUP. When you toggle right you will be offered four playback options: NORMAL, SLIDE, FADER and ZOOM. When selected you will get the following effects: NORMAL - Each image instantaneously replaces the previous image. SLIDE - The images are sequenced by sliding from right to left. FADER - The images are sequenced via a lap dissolve. ZOOM - The images are sequenced by zooming in to black and zooming out from black.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
90 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
robert landry
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
