Question about Liebherr Refrigerators
I have a Liebherr KGT es 4036 fridge freezer. The freezer temperature has risen to - 4centigrade and will not retrun down to - 18centigrade. Its like this for a good few days now. Has any one any sugesstions as to what the problem might be? Regards MOC.
SOURCE: we have a liebherr 7082
The two flahing lights are normal if the freezer is warm. It will display temperature when it gets cold. If it doesn't get cold there is another problem.
Posted on Aug 09, 2008
SOURCE: liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Posted on Jan 04, 2009
SOURCE: my fridge freezer is omitting cheesy smells from
Im still looking for the same problem and how to solve. Ive established it stagnant water in the drip pan at the rear. I keep cleaning it and intermitantley it comes back with water that looks like cheese curd in it........ Im going to call Liebherr as the fridge has been doing this since last year and is now getting worse but is only 2 years old.......
Posted on Mar 08, 2010
SOURCE: Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
Posted on May 12, 2010
Why would the freezer and fridge temperature indicators flash after a few hours of the unit being switched on?
Hi, some fridge freezers the indicators flash as they have not got to the right temperature yet. Also some freezers have indicators that will start flashing to let you know that the door has been open to long and the freezer temp has risen.
Jan 20, 2016 | Refrigerators
I have a Liebherr CUPsl 3221 freestanding fridge/freezer. Does any one know what are the approximate temperatures in the freezer area at different settings? (1-7, manual button in the refrigerator are
Their are no direct connections between the number and the temperatures on refrigerators and freezers. Is is based on surrounding temperature, in the room. That is the reason they used numbers and do not mark teperatures.
May 23, 2014 | Liebherr Refrigerators
Liebherr KD 900 fridge freezer bought 2001. Both the freezer and fridge are losing temperature, as though it is defrosting and then clicks back on and seems to regulate itself again. This has happened...
The defrost timer sticks in defrost mode and then comes out of it. I've been out of the service industry long enough to not be able to tell you on your model where it is located. Defrost timers on frost free refrigerators are a very common problem.
Oct 11, 2017 | Liebherr KES3660 Stainless Steel...
How should I set the temperature. The refridgerator and freezer is not able to maintain a consistent temperature. What is the correct freezer and top refridgerator setting and how do I know it has accepted...
Basically the thermostat controlls the freezer temperature which turns the compressor on and off.
The refrigerator section receives cold air from the freezer to cool it down.
So when the freezer is off there may not be enough cold air left for the refrigerator.
Fridges can never give you a perfect temperature every time there will always be a drift one way or another.
Once you reset the temperature the numbers or an led should blink at you to confirm the changes you made
Mar 25, 2011 | Liebherr KGK 2833 Comfort Bottom Freezer...
Freezer not freezing, or if it is lettuce etc in fridge freezes
With fridge freezers, there is usually a solenoid at the back that controls where the refrigerent goes. It consists of a sealed valve and a solenoid coil. It is possible that this has become open circuit so cannot direct refrigerant to the freezer section.
Another alternative problem may be the thermistor in the freezer section. This sensor will tell the control board the temperature in the freezer section. If it gets it wrong, then the freezer will overcool or not cool at all. Often a manufaturer will standardise on a part, so swapping the fridge and freezer thermistors around can identify that this is the fault - then just buy another 1.
If these tests don't work, you're looking at a new control board. Second hand ones may be available.
Best of luck.
Feb 08, 2010 | Liebherr Premium K 2954 Top Freezer...
Fridge will not turn down
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Liebherr KES3660 Stainless Steel...
Freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new...
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Miele Refrigerators
Liebherr frost free fridge/freezer
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Refrigerators Logo
53 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
