Question about Lavazza Espresso Point Capsule Machine
Water leek from the block, I allready change one before but the store I buy from is not there anymore can you tell me ware to find parts for the lavazza point
  • mprivilegi1 Nov 07, 2010
    I have the lavazza point matinee using capsule
    I don't know if gaggia make the lavazza but I need the heating section the whole block were I can buy that???
    President:
  • 2,777 Answers
There are a few places to find the parts, if you want to find them locally please reply back to me here with your zip code and I can track someone down.
Online you can buy them from:
http://www.espressozone.com/lavazza-espresso-point-parts.aspx
Please let me know though, just reply to my answer here.
Thanks!
Tim
Posted on Nov 07, 2010
  • 1,711 Answers
The Lavazza Espresso point machines is aproduction of the Saeco-Gaggia group and their thermoblock are the same. Try this lnk which they can help find the matching block.
You can contact them if they don't show it in the online shop since they can supply many other parts that they don't show. They will be more than happy to help you.
http://www.partsguru.com/Saecoparts.html
  • espressonist
    espressonist Nov 07, 2010
    As we have mention your machine is a Saeco Gaggia, the thermoblock (boiler) is the same as other saeco and gaggia models. Online there is not any specfic page that you find this thermoblock. However at the link we have mention they can give you a specific answer to your email request.
Vehicle is losing water. Already changed water pump. Unsuccessful at resolving issue.
are the carpets in side dry might be leeking from heating unit cylinder head jackets leeking you would see the water running down the sides of the engine split hoses leek in radiator or expansion tank hoses how much does it lose has the mechanic done a pressure test there could be a crack in the block or cylinder head a pressure test would find all these leeks
Mar 26, 2015 | 2003 Buick Regal - Supercharged 3.8L V6 -...
Water leeks out of pump
Ware on the pump dose it leak because it dose have a tempature sensitive blow out valve 145 degrees water temp . And what kind of pump is on this mechine CAT MITI M or simpsion al though it could be a lot of other brands from all over the world because no one builds it all with power washers they may put there name on it but use parts from all over
May 20, 2012 | Honda Pressure Washer PSI 3000
I have a little water leek from a small pipe under where the heater hose pipes meet the top of the engine could you tell me what it is it only leaks when the engine is cold my car is a 2001 pontiac...
it's a thermostat bi-pass and not uncommon to rust especially if the anti freeze coolant has not been changed on time. some can be changed some are part of the water pump, if you do not have a repair manual go to your local library and see if they do. Other wise the book stores especially used one, all carry them. The one I like,is called auto repair for dummies, they have pictures as well as an easy to read format.
Sep 29, 2010 | Pontiac Bonneville Cars & Trucks
Can i mix water and anti freeze in my car
yes just pour in rougly equal amounts of water and coolant or use the ready mixed type avail at any auto parts store, the ratio is 50/50
Aug 25, 2010 | 1997 Plymouth Breeze
Water is leeking from the pressure valve ware can i get spare parts for it
the nearest part dealer /or/ try to look up by model#/or/ call #on machiene
May 14, 2010 | Garden
Regal Ware Kitchen Pro Breadmaker model6725 belt
You can order both here:
http://www.vendio.com/stores/breadmakerguru/category?top_searchString=6725+regal+ware&searchString=6725+regal+ware
Nov 25, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
There is a water leek some ware in the back of the engine and runs down by the starter, and can not find the leak 1997 Jimmy
Could be the intake manfold, the big block that the carborator sets on. It is common for these to start leaking on this engine. Hopefully it is just a heater hose leeaking. Changing the intake could be expensive. If it is the intake, it will cause the jimmy to overheat eventually. look between the intake and were it bolts down to the engine aroung the area you see the water coming from.
Jun 23, 2009 | 1997 GMC Jimmy
WATER AND RADIATOR
You can buy some stop leak solutions at your local car parts store, but that is only a temporary fix. You will probably have to get it checked out by a proffessional.
Jun 01, 2009 | 1994 BMW 5 Series
Water in cylinder
The absolute "cheapest" fix is to go to your local auto parts store & buy a can of a product that is called "Block Seal" or something like that (terminology changes from region to region); tell the parts guy your problem & he will sell you the right stuff. Read & follow the directions. I cannot guarantee that it will work 100% (as we both have no way of knowing exactly how bad the situation is without disassembly), BUT, I have personally used "Block Seal" several times, and have had good results.
Try it. If it works, you will haved tons of $$$. If it does not work, you will need to pull the head & replace the head gasket. Hope this helps.
Oct 03, 2008 | 1994 Honda Accord
A bad leek on the back of my block
Usually they leak from the oring at the back of the water pump but the water runs in the middle of the V of the block and goes at the back. If you've got the manifolf off you should be able to locate the middle pipe and see if it's corroded or leaking. Could be as well the frost plugs at the back of the heads??
I think you should be not too far away from seeing the leak if you've already got your manifold out. Good luck.
Jul 08, 2008 | 1998 Mitsubishi Montero Sport
Lavazza Espresso Point Capsule Machine Logo
167 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
