Question about Panasonic SC-HT940 System
F61 fault i have a panasonic sc-ht940 that shows f61 i remove the sound ic and f61 still desplay can you say why
  • jholleran Jul 20, 2008
    I have a Panasonic homer theater system. I get an f61 when I turn it on, then it shuts down. I tried unplugging it for a minute but that did not work.
    I am electronically illiterate. Please explain in easy tu understand terms.
  • Anonymous Feb 06, 2009
    THE UNIT CAME IN WITH F61 THEN I DISCOVERED THAT THE FRONT LEFT CHANNEL GOT VOLTAGE ON,MAKING BUSING NOISE,I REPLACED THE IC RSN 311W64 WITH ORIGINAL IC FROM PANASONIC ,THEN BUSING GONE BUT STILL F61 THEN SWITCH OF,AND I,VE GOT YEARS OF EXPERIENCE PLUS MY OWN REPAIR SHOP.PLEASE CAN SOMEONE HELP ME
  • 32 Answers
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Posted on Sep 21, 2008
    Champion:
  • 208 Answers
Hi, there is a service bulletin from panasonic for this kind of problem, I can't lay my hands on it at the moment, but to cut a long story short, there are other components on the main PWB that need to be replaced because they have been "fried" because the customer has been leaving the unit switched "on" 24/7 instead of setting it back to "standby" when they have finished using it.
Posted on Feb 07, 2009
Check the regulating STK,IC or transistors.if any of the other major +v supplys are getting short somewhere.
Posted on Jul 13, 2008
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
My SC-HT650 system reads F61. I think I need a new transformer. Where do I find that?
Not the transformer. probably needs a voltage ic or output ic. F61 is a voltage error code. if it was the power tranformer it would not power up at all. It also could be just a bad fan. The fan should start as soon as you turn it on.
Jan 26, 2011 | Panasonic SC-HT650 System
WHAT DOES F61 MEAN ON DISPALY SCREEN
Panasonic customer service told me it was a problem with the power supply. I took it to a local repair shop and it turned out to be the cooling fan. Pretty cheap fix. This is the last Panasonic product I will purchase
Jun 24, 2010 | Panasonic SC-HT940 System
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
Stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Oct 15, 2009 | Audio Players & Recorders
F-61 error
F61 IS A PROTECTION FAULT.POSSIBLY YOUR FAN OR AUDIO STAGE IS FAULTY
Jul 18, 2009 | Panasonic SC-HT940 System
F61
check the fan
If one fan dosent work it will show the error F61
May 15, 2008 | Panasonic SC-HT940 System
Panasonic sa ht530
REPLACE RSN IC(SOUND AMPLIFIER THEN CHECK AND REPLACE 2 -3 SMALL TRANSISTORS TWO 2SC3199 AND ONE 2SD592 THEY RE ON THE AMPLIFIER BOARD,EVEN WHEN RSN IC IS REMOVED SHOULD NOT SHOW F61 AFTER YOU'VE REPLACED THOSE TRANSISTORS
Mar 21, 2008 | Panasonic SC-HT730 System
F61
Output IC is defective.Not much to do except have the main unit serviced.Output IC is rather costly.Before taking it for service, disconnect all speakers and power on.In F61 comes up IC is definetly bad.If unit works reconnect 1 speaker at a time(with power off) and retest each time.Repair bad speaker .
Nov 27, 2007 | Panasonic SC-HT740 System
Panasonic SC-HT940 System Logo
904 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
