Question about Goodman GPC1342H21A Air Conditioner
Fan will not shut off when heat is on. Have thermostat set on 68. Has been running now for 3 hours.
  • Goodman Master
  • 43,501 Answers
Make sure the fan switch on the t-stat is not set to the "on" position....
If not then the fan or fan and limit switch in your furnace may be bad.....
or sometimes if your unit has a fan relay on the control board that will go bad and then the whole board needs to be replaced...
heatman101
Posted on Nov 07, 2010
I turned my thermostat down this morning to 68 degrees. I came back about 2 hours later to increase the temp to 70 degrees but when I push the ^ arrow instead of showing the increase to 70 it just flashes...
Since it's within 2 degrees of your setting it could be one of two things. Most furnaces run longer (pass your setting) to maintain the setting you made. Which really not a problem. However, your thermostat may need calibrating. To test this theory, place a regular wall thermometer next to your furnace's thermostat and see if the two temps match when the furnace cuts on and then when it cuts off.
If the temps are both the same, the furnace thermostat is fine.
If you're turning it down to 68, because no one will be at home during the day, just set it 2 degrees cooler than 68 degrees. You will then wind up with 68 degrees.
Feb 09, 2011 | Heating & Cooling
The thermostat is set to heat at a temp of 68 degrees. However,the thermometers temp read 71 and the blower was running and passing cool air. I tried setting the thermometers temp to 72. The furnace...
The burners are not igniting and the timer turned on the blower thinking the burners were already lit by then. You have a burner/ignition problem. Either the ignighter or themocouple is bad
Dec 31, 2017 | Goodman GMS90703BXA Heater
Payne AC not working. 1. Thermostat set 68 to AC w/fan on. 2. Breakers and switch near heater are on. 3. Outside unit has 220v but is not running. 4. Fan in heater/Ac unit is not running 5. ...
Dan is this a new system, or has some work on the system (to include the thermostat) been done recently?
Sounds like the thermostat may be wired wrong. From what you describe, the igniter element is coming on, as though you are calling for heating. Do you allow the ignitor to keep going and see if the gas fires off, or are you seeing this and shutting down the system immediately?
If you had the t-stat changed recently, or this is a new system, contact the installing contractor. It may be under warranty.
Sep 03, 2010 | Carrier Heating & Cooling
I have to play with thermostat to get my heating system on
You did not make it clear if the thermostat is a programmable unit or not. I am wondering if the thermostat is not set on the correct heat anticipation setting. A heat anticipater is a small heater that helps the thermostat turn off before it over shoots the desired temperature setting. If the thermostat is set for a 5 degree setting, it will turn off at 63 degrees if set at 68. If the anticipater was set at 1 or 2 degrees, it will shut off the heater at 66 or 67. Newer thermostats will only allow the thermostat to cycle 6 times per hour so if you never reach the desired temp, you have to wait 10 minutes before it will allow a call for heat. Check the installation instructions to see if there is a setting where you can get the anticipator temperature closer to your set temp. Good luck.
Dec 11, 2009 | Goodman Heating & Cooling
Rheem heat pump. blower will not turn off
The fans are set to delay for 60-90 seconds to remove all heat from the heat exchanger/heater elements.
If the fan runs any longer than 3-4 minutes after the Emergency Heat shuts off, you may have a bad sequencing relay in the air handler.
Jan 27, 2009 | Heating & Cooling
Honeywell programable thermostat not recognizing nigh time settin
This is the problem you have when you rely on "modern electronics". Suggest you buy a manual 'stat and just turn down the temp at bedtime. Make it cold and use a blanket, that is what we did in the " good 'ole days".
Jan 12, 2009 | Honeywell Programmable Heat Pump...
Goodman GPC1342H21A Air Conditioner Logo
41 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
