Question about Homelite ZR10926 16 Chain Saw
I am trying to find out the bar and chain part number I was given a John Deere J3816 chain saw with no bar and chain. do you know what the part number is?
  • 25 Answers
Organ makes a replacement combo bar/chain for the j3816. Part # is 105700. You should be able to find it in most stores like Lowes or Home Depot. You could also go on line to wwwOrganchain.com. Hope this helps.
Posted on Nov 07, 2010
John deere 60v chain saw how to take apart to get at the oil tank
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 11, 2017 | John Deere Garden
Where is the chain tighten screw on john deere j3816
The tensioner adjustment is on the bar. If you cannot find it, then someone has replaced the original bar with a non-adjustable one. Here is a link to a manual; https://groundscare.custhelp.com/ci/fattach/get/51671/0/session/L2F2LzEvdGltZS8xNDQ1ODU5NDcyL3NpZC9tcjZCaFZ6bQ==/filename/554+-+OM_J3816_UT10945_PS05064.pdf
Oct 23, 2015 | John Deere Garden
Why does my john deere chain saw leak a lot of bar oil after i get done running it?
There bar oil seal is not that great it wears out right away and leaks instead of squirting oil when you pump it.
Don't worry 80 % of all chain saw leak sooner or later. Just put oil when you use it then drain it when you store it.
Oct 19, 2014 | Garden
Need gas cap for john deere 40v chainsaw
Take your saw to a lawn and garden shop that repairs chain saws. They should be able to help.
Aug 07, 2013 | John Deere 28 30 40v 50v 55v 60v 70v 80ev...
I have a J3816 chain saw. I need a new chain. What do I look for? I understand it is a Homelite in JD clothing. loadmike@yahoo.com
I don't know what suppliers you have in your area but where I live tractor supply, orechlins,and true value all have good selections of chains and knowledgeable sales staff. Most have a selection booklet that lists proper chain selections fo bar length, manufactures, chain type [ low kickback, fast cut, etc.]
You will need model number, manufactures name, chain length, type of chain you want. I would use the low kickback chain in almost all types of wood. About the only type of wood that I would use a more aggressive chain on is soft high moisture content woods like cottonwood or certain elms and pines. I hope this helps you. Thanks
Dec 05, 2010 | Poulan Pro Chain Saw 46cc 20"
What part number oregon chain do i need for a cs-52 john deere saw. They keep sending me the wrong john deere chain witch is three links short. thanks Vern.
Hello Sam;
I cannot find anything by Deere (probably an efco 152) about your saw. Oregon does list some particulars here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
I input:
John Deere; CS52; *see below; All (0.325"); All (0.050"); All (yours is likely green - low kickback).
*16" - 66 drive links (the part that fits in the bar).
*18" - 72 drive links.
If your saw does not use either 66 or 72 drive links I suspect the bar, drive sprocket, or drive sprocket and bar nose in use are not what the the saw was originally supplied with. Any local chainsaw seller/mechanic given your chain as a pattern can fabricate one in about 5 minutes. Often a local chain is less expensive (no shipping).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
efcoPower.com
http://www.efcopower.com/indexPri.jsp
Sep 07, 2010 | John Deere 16" Chain Saw Chain (Oregon ...
WHERE IS THE GAS TANK VENT IN A JOHN DEERE J3816 CHAINSAW AND HOW DO YOU CHECK IT TO SEE IF IT IS PLUGGED ?
The Vent is usually part of the fuel cap. If the saw is starving out losten the cap slightly if that fixes the problem investigate further. Lou
Aug 26, 2009 | Garden
Homelite ZR10926 16 Chain Saw Logo
272 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
