Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
NETGEAR WGR824 v1 I have this router for almost 2 years now. It has always been running smooth and I had no problems with it untill today. When I turned it on, it kept freezing with all the lights lit. I reset the router using the reset button on the back hoping it would solve the problem, but it turned out it kind of bricked my router. When I plug it in, the power light lit, then the check lit, then the WIFI light would blink twice and only the power light left lit. I wanted to re-install the firmware but I cannot access the router since it's unable to be detected by my PC on all the 4 ports. I called netgear they're very certain they could fix my router for $99.99. I would really appreciate if someone could please help me solve my router problem. I really need hour help. Thank You very much. God bless you.
sandrew
  • 2961 Answers
SOURCE: The lights won't turn off
there is something wrong internally, i think, but if you can get into the routers settings via your browser using an rj45 cable (192.168.0.1) and enter the username and password normally admin and 1234 or admin and admin, and look for reset in the menu or restart router. If you are able also look under your router for the firmware version or it can be found somewhere within the settings menu and go to the netgear website and see if there are any firmware updates. If there are you will have to install it following the instructions and probably have to do a factory reset to initiate the firmware, if still having the same problem the hardware itself may be faulty.
Posted on Jun 15, 2007
  • 104 Answers
SOURCE: No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Posted on Jan 11, 2009
redhaze89
  • 854 Answers
SOURCE: My NetGear WGR614 v1 stops broadcasting and needs to be repowered
I suggest you do a firmware upgrade. But in doing this, you will loose the settings on your router. You have to reconnect all you devices on the new settings.
Please follow this steps:
2. Download this link ftp://downloads.netgear.com/files /wgr614v1_1400.zip
3. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. Before you upgrade, write down all current settings as you need to enter them manually after upgrading.
4. Using the computer hardwired on the router, open any web browser like Internet Explorer or Netscape Navigator.
5. Connect to the router by typing http://192.168.0.1 in the address field and click Enter or Return key.
6. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Setting the router:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://192.168.0.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Sep 18, 2009
  • 73 Answers
SOURCE: I have two routers Netgear DG834Gv3 and Thomson
I am sorry but I am not so familiar with the Thomson Device but I can give you a clue on how to set it up....you can skip the security settings first just make sure they work then you can set it later...Check it out!
- Thomson as "Master Router" connected to modem set up as follows
-- 192.168.1.1
-- Set up wireless access point as you normally would in Wireless Settings, muine are "MY_SSID",Channel 2,b+g mode,
64-bit WEP with hex key (rather than pass phrase)
--- Enter any laptop wifi MAC addresses in the "Client Access List" here to allow them and make sure it's set to restrict
them
-- Set DHCP range to 192.168.1.10 to 192.168.1.127 (my preference) in "Lan Settings"
-- go to Wireless Bridging and Repeating menu option
--- Set "Enable Wireless Repeating Function"
--- Set as "Wireless Base Station"
--- DO NOT check the "Disable Wireless Client Association" if you want to be able to use laptop wifi
--- Enter the mac address of your "Slave Router" here
Make sure all of the above is applied and has stuck, i had a habit of setting some things then clicking to a sub-menu
before clicking apply, always scroll down and click apply before drilling into sub options!
DG834G V3 : "Slave Router"
-- Get latest firmware as earlier v3 firmware doesnt support WDS
-- 192.168.1.2
-- Enable Wireless Settings and set to exact same as "Master Router" including 64 bit WEP key and MAC access list for
laptops etc
-- Disable DHCP in Basic Setup (I think)
-- "Advanced Wireless Settings" menu option
--- "Enable Bridging and Repeating"
--- Select the "Wireless Bridge With Client Association" (or similar) option
--- Enter the "Master Router" MAC address here
Again, double check everything has stuck, that the "normal" wireless settings for both routers are identical and reboot
both (in either order worked for me but booting the Master first is probably best practise)
GOOD LUCK!!!
I
Posted on Oct 27, 2009
Testimonial: "Thank you for the step by step guide, but some pics would have been helpful. Sorry since I am a beginner to WDS systems."
Geekman
  • 32281 Answers
SOURCE: Netgear Router WGR614 Problem, 1234 Lights Lit Orange, No Connect
Try resetting the Netgear back to the factory default and then configure the wireless setting.
Press the pinhole RESET button on the back of the Netgear until all the LEDs flash then connect a LAN cable from the computer to the Netgear open a browser and enter the configuration URL IP address
http://192.168.0.1
Posted on Jan 01, 2010
Testimonial: "Thank You, for taking your time to answer my problem... Eventhough my problem wasn't solved yet, I wanted to thank you for helping us all."
Cannot login into my netgear dg834gb v2 for remote management
Here is a site for your new firmware version:
http://kb.netgear.com/app/answers/detail/a_id/262/~/dg834(v1-%26-v2),-dg834g-(v1-%26-v2)-firmware-version-2.10.22
Here is a site for your product:
http://kb.netgear.com/app/products/model/a_id/2324
Maybe you have to reset it to factory settings.
There is a button next to the power inlet prees it with a pen.
Here is how you acces the router again:
  • IP address: 192.168.0.1 type this in your browser
  • Username: admin
  • Password: password (Sky-branded units have a default password of sky)
  • Function set to Router + Modem
To access the Setup Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
A video walk-through of installing and configuring your router using the Smart Wizard is available at http://kb.netgear.com/app/answers/detail/a_id/12873.
Hope this was helpfull.
Mar 17, 2011 | NetGear DG834G Router
For aboutfive years i have successfully had a orange live box installed in my home and, again successfully have 2 wireless computers. How ever my oldest computer doesnt have wireless option installed on to...
First be sure to check the drivers for your Netgear WG111 are up to date and correspond to your Operating System. It is important to note that there are three versions of the WG111. If you visit the Netgear's Knowledge Base site you can see the difference between the 3 versions (v1,v2 and v3) and select the one that corresponds to you. If you don't know what version you have look for a v1, v2 or v3 after the model name:
After you determine which version you have, let suppose its v3, click the link corresponding to it and download the Software Version 2.0.0 (Supports Win 7) if you are using Windows or the WG111v3 Mac OS Driver Version 1.0.0.0 if you are using a Mac. Once you download the file, run the executable file and install the driver/software for your device.
If your problem is not with drivers then youshould look at you Wireless Network Setup. Please Check that the router has a source of a working internetconnection plugged in correctly via an ethernet cable. Also, routers need fromtime to time to be rebooted. Try disconnecting the router from the power sourcefor 15 to 10 seconds and connect it again.
Post more details concerning your OS, the router you are using and what type ofinternet connection you have(DSL or Cable).
Mar 05, 2011 | NetGear WG111 802.11g/b Wireless Adapter
Dg834gsp have a new ps3 which is not conecting. the wii had no problem
You need a firmware update.
You will be able to find it here: http://kb.netgear.com/app/answers/detail/a_id/262/~/dg834(v1-%26-v2),-dg834g-(v1-%26-v2)-firmware-version-2.10.22
Dec 28, 2010 | NetGear DG834G Router
1 year old Toshiba Laptop will not connect to NETGEAR wgr614v9
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 12, 2010 | NetGear WGR614 Wireless Router
Netgear router download
Sure, but you have to go searching. There are 10 versions, v1-9 and L.. Look at the label on your router and click on the following link.
http://kb.netgear.com/app/products/family/a_id/1296
Then click on the appropriate version.
Carl
Nov 11, 2009 | Computers & Internet
I have a THOMSON ST585v6sl with AOL running off
Well it may be possible, only if your wireless router supports WDS. Also, note that in DG834Gv3 , v4, v5 supports WDS. If you have v2 or v1 then it wont connet wirelss with your existing network.
Please reply if your existing wireless router has WDS and the version of the NETGEAR router so that I will provide you with the required steps to make it work wireless.
Jul 13, 2009 | NetGear DG834G Router
I had changed some information with the netgear on my computer.
Type in your browser:
http://192.168.0.1
then user= admin
pass = blank (no pass) or the word password
after that you will have access to the settings of your router and see what is going on there.
Feb 09, 2009 | NetGear WGR614 Wireless Router
Jan 11, 2009 | NetGear WGR614 Router
Netgear Wireless Router 108 MBPS
It's not the same. Your Netgear router version is V1. I did not find any downloadable upgrades either - I have the same router. My connection problem turned out to be between my DSL modem (AT&T), router and PC. What I needed to do was, under "Basic Settings," click no where it asks if your service requires login, then at the bottom of the tab, click the option to acquire the MAC address directly from the wired (desktop) computer. ("this computer" on the tab) Once I had done that, the router enable the modem correctly and I could use the desktop and the wireless access for my laptop. Frustrating, because if you have AT&T as your service provider, Netgear's instructions tell you to do the exact opposite.
Jul 17, 2008 | NetGear WGT624 Wireless Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
127 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
