Question about Kenmore Oasis HE 27082 Top Load Washer
My KEModel 27086 stops during the cycle (any cicle) and shows code F1, I know is either an "air hose" or a computer board; how hard it is to "do it yourself" ?
  • Kenmore Master
  • 1,711 Answers
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Nov 07, 2010
I have a Kenmore Elite Oasis HE (Model# 110.27086603). I receive an F1 error code after starting the machine. It takes 2 stop & starts to reset. I then receive the F1 error code again at the rinse...
F1 Error Code
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure switch/sensor hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is damaged.
B) Moisture in the air pressure switch/sensor hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing. Blow through the hose to clear any lint that may be trapped in the hose.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on the tub.
D) The control board needs to be replaced.
a. Replace the control board only after the prior steps have been performed, and not fixed the problem.
Feb 27, 2011 | Washing Machines
Kenmore Elite Oasis stops mid-cycle. Get F1 display on panel.
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!
Dec 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore oasis st 6806 fault code f1 during first steam cycle
Nov 30, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
During any washing cycle the washer stops and beeps. F1?? You end up having to press "pause" and start again about 6 times each wash. What can I do to fix it? Is it board?
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
A) Air leaks in the air pressure (switch/sensor) hose.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite washer F1
Oct 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F1 error message wash cycles and rinse cycles
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error code on Kenmore Oasis He
Jun 02, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Apr 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis he washer error code F1 or Fl
Apr 07, 2009 | Kenmore Washing Machines
F1 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
Mar 21, 2009 | Kenmore Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
407 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
