Question about Maytag MER6772 Gemini Electric Kitchen Range
Need to set the clock on my electric maytag gemini stove
WhIzAtIt
  • 136 Answers
SOURCE: Maytag MER6772 Gemini ELectric Stove
F9-3 code means the latch on the oven is faulty. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=MER6772BAQ&PartCategoryName=&Keywords=latch
Posted on Sep 17, 2007
aborcass
  • 2651 Answers
SOURCE: MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Posted on Mar 06, 2008
aborcass
  • 2651 Answers
SOURCE: maytag,electric stove-
you need to order a custom control kit, electronic switch that contorls onlly that one burner
Posted on Mar 11, 2008
SOURCE: gemini electric range from maytag
Just unplug it and plug it back in. It will reset it.
Posted on Jun 05, 2008
reg501
  • 413 Answers
SOURCE: Maytag gemini schott ceran stove top
Sugar spills on a hot surface will 'pit' the glass surface. There is no way to repair. The damage caused to the surface is only cosmetic and will not affect the performance or operation.
Posted on Jun 21, 2008
Electric range for maytag gemini stove doesn't coem on. Clock and controls appear to function. This is after I turned the house's breaker off then on again. The "On indicator" light does not come on when I...
Turn it off at the circuit breaker and leave it off for a few minutes,sometimes the microprocessor will reset itself. When you turn it back on make sure the safety switch is working ok they usually have a test button on them.
May 01, 2014 | Maytag MER6772 Gemini Electric Kitchen...
Elements work but both ovens and clock face are off
Reset breaker or unplug and restart stove. Open back of stove to clock face and make sure the harnesses are tightly fitted to clock board. You could even remove and reinstall the harnesses to the clock board.
If able, check for 120v to clock. If clock is getting power but not lighting up, replace clock.
You did not say whether the clock controls the oven; ie. oven does not work when clock is off. if so, replace clock. If not, ignore it unless you want to know the time from that clock.
Oct 20, 2013 | Maytag GeminiĀ® MER6765BA Electric Kitchen...
I am getting error code F1-8, and the stove beeps randomlt and the front panel is not functional?
f-1 is a defective touch pad or clock and 8 is analog/digital problem. the solution for this is to replace the clock and touchpad
Sep 17, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
How do i clean the top of my gemini stove
Use Baking Soda and water and form a paste. Use this to clean the top of your stove. If food is really baked on, you might also consider using a single blade razor to scrape the mess off. Rinse well.
Sep 21, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
233 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
