Question about Samsung SGH-S5230 Cell Phone
Can i get panel of it ??? where ? - Samsung SGH-S5230 Cell Phone
  • 217 Answers
You can get panel for your moblile in your nearest Samsung showroom.Try it.
Thank you
Posted on Nov 07, 2010
What will cause a sunroof not to close properly on a 2007 Milan
A lot of thing's , has sensors , switches , a control module , relay's etc....
The roof opening panel is an electronically operated panel that can be opened or closed by pressing a switch located on the overhead console. It also has one-touch open, one-touch close, one-touch vent open and one-touch vent close features.
Roof Opening Panel The roof opening panel assembly uses an integrated motor and module to operate the roof opening panel. The roof opening panel motor and module are installed new as an assembly. The roof opening panel is an electronically operated glass panel that can be opened, closed or tilted by the roof opening panel switch. Actuating the switch in either a forward or rearward motion supplies a ground to the roof opening panel motor/module. The roof opening panel has one-touch open and one-touch close features that are activated when the switch is momentarily pressed to the double detent OPEN or CLOSE position. These functions are controlled by the roof opening panel motor/module.
The roof opening panel motor must be initialized whenever the roof opening panel motor has been removed from the roof opening panel system, the roof opening panel assembly has been removed from the vehicle, a new roof opening panel motor has been installed or a new roof opening panel assembly has been installed.
Plus the mechnical parts of it .
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel trough
  • Roof opening panel air deflector assembly
  • Roof opening panel seal
  • Roof opening panel shield
  • Battery junction box (BJB) fuse 33 (20A)
  • Smart junction box (SJB) fuse 12 (7.5A)
  • Circuitry
  • Accessory delay relay
  • Roof opening panel motor and module assembly
  • Roof opening panel switch
Mar 20, 2017 | 2007 Mercury Milan
Sunroof will not close. Was working fine earlier today
The roof opening panel assembly uses an integrated motor and module to operate the roof opening panel. The roof opening panel motor and module are installed new as an assembly. The roof opening panel is an electronically operated glass panel that can be opened or closed by the roof opening panel switch. Actuating the switch in either a forward or rearward motion supplies a ground to the roof opening panel motor/module. The soft-stop function is controlled by the roof opening panel motor/module. The roof opening panel has 3 modes of operation, manual mode, express open and tilt. The express open feature is activated when the switch is pressed momentarily. The tilt feature is activated when the tilt switch is depressed. These functions are controlled by the roof opening panel motor/module.
  • Roof opening panel water trough
  • Roof opening panel rear trough guides
  • Smart junction box (SJB) circuit breaker 47 (30A)
  • Circuitry
  • The roof opening panel does not open or close - one direction only
  • Circuitry
  • Roof opening panel motor assembly
  • Go To Pinpoint Test E .
PINPOINT TEST E: THE ROOF OPENING PANEL DOES NOT OPEN OR CLOSE Test Step Result / Action to Take E1 CHECK THE ROOF OPENING PANEL LIFTER ASSEMBLIES FOR OBSTRUCTIONS OR DAMAGE
  • Check the roof opening panel lifter assemblies for obstructions and damage.
  • Are the roof opening panel lifter assemblies OK?
Yes
GO to E2 .
No
REMOVE all obstructions and REPAIR any damage. If lifter assemblies cannot be repaired, INSTALL a new roof opening panel frame. REFER to Roof Opening Panel Frame in this section. TEST the system for normal operation. E2 CHECK THE ROOF OPENING PANEL WATER TROUGH AND REAR TROUGH GUIDES
  • Check the water roof opening panel water trough and rear trough guides for any loose obstructions.
  • Are the roof opening panel water trough and rear trough guides installed securely and free from obstructions?
Yes
GO to E3 .
No
REMOVE all obstructions from the roof opening panel water trough and install securely. SECURE the rear trough guides or INSTALL new roof opening panel rear trough guides if damaged. REFER to Roof Opening Panel Rear Trough Guide in this section. TEST the system for normal operation. E3 VERIFY THE ROOF OPENING PANEL ADJUSTMENT
  • Verify the roof opening panel is adjusted correctly.
  • Is the roof opening panel adjusted correctly?
Yes
GO to E4 .
No
ADJUST the roof opening panel. REFER to Roof Opening Panel Alignment - Horizontal Adjustment and Roof Opening Panel Alignment - Height Adjustment in this section. TEST the system for normal operation. E4 CHECK THE ROOF OPENING PANEL MOTOR/MODULE FOR INITIALIZATION
    NOTE: The roof opening panel motor initialization procedure must be done when repairs are carried out on any part of the roof opening panel assembly, including whenever the roof opening panel motor/module has been removed from the roof opening panel assembly, a new roof opening panel motor/module has been installed or when a new roof opening panel assembly has been installed. Refer to Roof Opening Panel Motor Initialization in this section.
  • Carry out the Roof Opening Panel Motor Initialization procedure. Refer to Roof Opening Panel Motor Initialization in this section.
  • If the concern still present?
Yes
GO to E5 .
No
The system is operating correctly. The roof opening panel motor/module was uninitialized. E5 CHECK THE POWER WINDOWS
  • Key in ON position.
  • Verify the power windows operate.
  • Do the power windows operate?
Yes
GO to E6 .
No
REFER to Section 501-11 to diagnose the accessory delay relay circuit. E6 CHECK THE ROOF OPENING PANEL SWITCH
  • Carry out the roof opening panel switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Did the roof opening panel switch pass the component test?
Yes
GO to E7 .
No
INSTALL a new roof opening panel switch. TEST the system for normal operation. E7 CHECK CIRCUIT CBP47 (GN/BU) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Roof Opening Panel Motor/Module C922.
  • Measure the voltage between roof opening panel motor/module C922-4, circuit CBP47 (GN/BU), harness side and ground.
  • Is the voltage greater than 9 volts but less than 16 volts?
Yes
GO to E8 .
No
VERIFY the smart junction box (SJB) circuit breaker 47 (30A) is OK. If OK, REPAIR the circuit. TEST the system for normal operation. E8 CHECK CIRCUIT GD143 (BK/VT) FOR AN OPEN
  • Measure the resistance between roof opening panel motor/module C922-3, circuit GD143 (BK/VT), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to E9 .
No
REPAIR the circuit. TEST the system for normal operation. E9 CHECK CIRCUITS CPR37 (YE/GY), CPR39 (VT/WH) AND CPR40 (YE/OG) FOR AN OPEN
  • Disconnect: Roof Opening Panel Switch C930.
  • Measure the resistance between the roof opening panel motor/module C922-1, circuit CPR40 (YE/OG), harness side and roof opening panel switch C930-8, circuit CPR40 (YE/OG), harness side. Measure the resistance between roof opening panel motor/module C922-2, circuit CPR39 (VT/WH), harness side and roof opening panel switch C930-11, circuit CPR39 (VT/WH), harness side. Measure the resistance between roof opening panel motor/module C922-5, circuit CPR37 (YE/GY), harness side and roof opening panel switch C930-14, circuit CPR37 (YE/GY), harness side.
  • Are the resistances less than 5 ohms?
Yes
GO to E10 .
No
REPAIR the circuit. TEST the system for normal operation. E10 CHECK FOR CORRECT ROOF OPENING PANEL MOTOR/MODULE OPERATION
  • Disconnect the roof opening panel motor/module connectors.
  • Check for:
    • corrosion.
    • pushed-out pins.
  • Connect all roof opening panel motor/module connectors and make sure they seat correctly.
  • Operate the system and verify that the concern is still present.
  • Is the concern still present?
Yes
CHECK the jumper harness between the vehicle harness and the roof opening panel for open or shorted circuits. If the jumper harness is not OK, INSTALL a new jumper harness between the vehicle harness to the roof opening panel motor/module. Otherwise, INSTALL a new roof opening panel module/motor. REFER to Roof Opening Panel Motor in this section. TEST the system for normal operation.
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. TEST the system for normal operation.
May 08, 2016 | 2008 Ford Expedition El
How do i change the heater core
big job. instrument panel has to come out.
Section 01-12: Instrument Panel 1997 Crown Victoria/Grand Marquis Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 05/16/2000
Instrument Panel SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Radio Removing Tool T87P-19061-A
Removal and Installation
  1. Raise vehicle on hoist.
  2. Remove RF wheel and tire assembly. Refer to Section 04-04.
  3. Remove three nuts in radiator coolant recovery reservoir area.
  4. Remove bolt retaining front fender apron (16054) to front fender (16005).
  5. Position front fender splash shield out of the way.
  6. Lower vehicle.
  7. Tag and remove main harness connector from jumper harness (located in front of blower motor).
  8. Remove LH instrument panel lower insulator (043A89) and instrument panel lower insulator (043A88).
  9. Remove steering column. Refer to Section 11-04.
    Instrument Panel Lower Insulators
    Item Part Number Description 1 04320 Instrument Panel 2 N807296-S Cap 3 388577-S Push Pin (6 Req'd) 4 043A88 Instrument Panel Lower Insulator, RH 5 043A89 Instrument Panel Lower Insulator, LH 6 - Module Bracket (Part of Module) 7 13466 Miniature Bulb 8 043A88 Instrument Panel Lower Insulator, RH 043A89 Instrument Panel Lower Insulator, LH
  10. Remove RH cowl side trim panel (02344) and LH cowl side trim panels (02345).
  11. Tag and disconnect wiring connectors in LH and RH cowls.
  12. Remove ground wire located on LH cowl side.
  13. Remove RH instrument panel upper moulding (04268) and LHinstrument panel moulding (04389) from instrument panel (04320) by pulling away from instrument panel and snapping out of retainers. Disconnect wiring connectors as required.
  14. Remove glove compartment (06010) as described.
  15. Remove two screws from center instrument panel support bracket at left side of glove compartment opening.
  16. Remove instrument panel upper finish panel (044A90) and disconnect the A/C sunload sensor (19E663) if equipped.
    Instrument Panel Finish Panels
    Item Part Number Description 1 044A90 Instrument Panel Upper Finish Panel 2 04320 Instrument Panel 3 04268 Instrument Panel Upper Moulding, RH 4 06081 Glove Compartment Lock Set 5 061A40 Glove Compartment Door Cover 6 N807122-S411 Screw (2 Req'd) 7 N807122-S411 Screw (10 Req'd) 8 - Parking Brake Release Handle (Part of 2780) 9 04459 Instrument Panel Steering Column Cover 10 04502 Instrument Panel Steering Column Opening Cover Reinforcement 11 04389 Instrument Panel Moulding, LH 12 044D71 Instrument Panel Cluster Finish Panel A - Tighten to 2.1-2.9 Nm (19-25 Lb-In) B - Tighten to 4-6 Nm (36-53 Lb-In)
  17. Remove five screws retaining instrument panel.
    Instrument Panel
    Item Part Number Description 1 N802539-S100 Nut (5 Req'd) 2 383554-S100 Rivet (2 Req'd) 3 01631 Vehicle Identification Plate 4 01544 Brake Pedal Support 5 N805632-S36 Bolt 6 N800854-S2 J Nut (2 Req'd) 7 N806030 Stud 8 N602480-S55 Nut 9 04320 Instrument Panel 10 N807122-S411 Screw (5 Req'd) 11 - Steering Column Retaining Nut 12 - Bolt (Part of 3F659) 13 3F659 Brake Pedal Support Steering Column Brace 14 N606675-S2 Bolt (3 Req'd) 15 04502 Instrument Panel Steering Column Opening Cover Reinforcement 16 N806067-S2 Bolt (2 Req'd) 17 N620482-S36 Nut 18 N801366-S2 Stud 19 045D56 Instrument Panel Cowl Brace 20 N606115-S100 Bolt (3 Req'd) A - Tighten to 9-14 Nm (80-123 Lb-In) B - Tighten to 10-14 Nm (89-123 Lb-In) C - Tighten to 2-3 Nm (18-26 Lb-In) D - Tighten to 47-63 Nm (35-46 Lb-Ft) E - Tighten to 45-70 Nm (34-51 Lb-Ft) F - Tighten to 22-34 Nm (17-25 Lb-Ft)
  18. Disconnect automatic temperature control sensor hose and elbow (19D888) from evaporator housing, if equipped.
  19. Disconnect vacuum hose harness assembly.
  20. On left side of engine compartment, disconnect all connectors and push harness through bulkhead.
  21. NOTE: The following steps should be performed be two technicians.
    Remove one nut and one bolt retaining left side of instrument panel finish panel (044D70) to cowl panel. Remove one nut retaining right side of instrument panel to cowl panel.
  22. Remove instrument panel finish panel from vehicle.
Jan 11, 2011 | 1997 Mercury Grand Marquis
How to take off the door panel on a 2001 Ford Escape
To take off your door panel, follow the steps below:
  • Raise the window of the door panel you wish to remove. Disconnect the negative battery cable and engage the parking brake for safety.
  • Remove the sail panel trim from the upper portion of the door panel. The sail panel panel is attached by clips; pop the panel off and disconnect the power window switch (if equipped).
  • Pull the interior door handle towards you to access the door handle trim screw. Remove the screw and slide the door handle panel off the door panel.
  • Pry up the window switch control panel and disconnect the electrical modules. Set the panel aside. Remove the three panel-mounting screws on the lower portion of the door panel.
  • Use the trim panel tool to help you pop the door panel clips from the door. Work your way around the entire door, until all of the clips are removed. Carefully remove the panel from the door.
Take care and good luck
Nov 06, 2010 | 2001 Ford Escape
My sunroof is not able to be closed. It is in the pop up position. Is there a manual way to close it? eg no use of electricity?
there is no manual method. It sounds like a limit switch is not working. Can you hear the motor try to operate? If you push up on the back of the glass a little bit while hitting the switch, what happens.
go here for villager help
http://groups.yahoo.com/group/villagerquest/
The sliding roof panel system consists of the following components:
  • RH circuit breaker
  • Timer module
  • Power window relay
  • Roof sliding panel switch (15B691)
  • Roof glass panel (50054)
  • Sliding roof panel motor (15790)
  • Halo moulding
  • Roof sliding panel headlining (519A02)
  • Roof sliding panel slide links (502M78)
  • Roof sliding panel housing (502C22)
  • Roof air deflector (500A26)
  • Center green diode strip
When the roof sliding panel switch is activated, a gear on the sliding roof panel motor drives a spline on the roof sliding panel housing. Within the roof sliding panel housing, the spline is connected to two sliding roof panel cables which cause the roof sliding panel slide links to slide and the roof glass panel to open or to close. The sliding roof panel cables and the spline are part of the roof sliding panel housing. Neither the sliding roof panel motor nor the roof sliding panel housing can be disassembled. If a malfunction is detected with either of these assemblies, the assembly must be replaced.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged sliding roof panel
  • Sliding roof panel height adjustment
  • Sliding roof panel fore and aft adjustment
  • Blown fuse(s):
    • 30A PWR WDW
  • Damaged circuit breaker #1
  • Damaged wiring harness
  • Loose or corroded connections
  • Sliding Roof Panel Does Not Open or Close
  • Fuses.
  • Circuit breaker #2.
  • Power window relay.
  • Sliding roof panel motor.
  • Roof sliding panel switch.
  • Circuit.
  • GO to Pinpoint Test E1 .
  • Sliding Roof Panel Will Not Stop in Vent Position
Switch Removal
  1. Disconnect the battery ground cable (14301).
  1. Gently pry the overhead console from the headliner.
  1. Disconnect the sliding roof panel electrical connector from the overhead console.
  1. Disconnect the rear quarter window switch electrical connector from the overhead console, if equipped.
  1. Disconnect the map lamp electrical connector from the overhead console.
  1. Remove the overhead console.
  1. Remove the two roof sliding panel switch screws and the roof sliding panel switch (15B691).
Motor Removal
  1. Place the roof glass panel (50054) in the closed position.
  1. Remove the roof headlining (51916). Refer to Section 01-05 for the removal procedure.
  1. Remove the two sliding roof panel relays from their brackets.
  1. Disconnect the two sliding roof panel motor electrical connectors.
  1. Remove the two sliding roof panel motor screws and the sliding roof panel motor (15790
Jan 11, 2010 | 1997 Mercury Villager
How to remove the inside door panel from a dodge 2005 2500 pick up
FRONT DOOR TRIM PANEL - REMOVAL
Release door latch and open door.
Roll window down.
Remove window crank Window Crank - Typical , if equipped.
Remove screws attaching trim panel to door Door Trim Panel and Trim Panel Screw
CAUTION: Do not forcibly pull trim panel from door, damage to trim panel may occur.
Simultaneously lift upward and outward to release retainer steps from inner door panel Trim Panel Retainer
Disengage inside handle linkage rod from inside handle.
Disconnect speaker harness wire connector Speaker And Power Mirror Connector
Disengage power mirror wire connector, if equipped (driver's side only) Speaker And Power Mirror Connector
Disengage clips attaching power window/lock switch panel to door trim panel. Disengage wire connector from switch panel, if equipped Power Door Lock/Window Connector
Separate door trim panel from vehicle.
INSTALLATION
Position trim panel at door.
Engage wire connector for window/lock switch panel, if equipped. Engage clips attaching power window/lock switch panel to door trim panel.
Engage power mirror wire connector, if equipped.
Connect speaker harness wire connector.
Engage inside handle linkage rod to inside handle.
Align trim panel retainer steps with inner door panel and slide trim panel into place.
Install screws attaching trim panel to door.
Install window crank, if equipped.
Hope helped with this; remember rated this help. Good luck.
Nov 12, 2009 | 2005 Dodge Ram 2500 Truck
How do you take the door panels off?
How To Install Replace Remove Front Door Panel Ford Focus 00-05 1AAuto.com
Nov 08, 2009 | 2001 Ford Focus
Need to remove drivers door panel
please rate if this helps. Section 01-05: Trim, Interior 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step. Trim Panels, Door Removal and Installation
  1. ssd~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
    Disconnect battery ground cable (14301) .
  1. Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item Part Number Description 1 23713 Front Door Trim Panel Finish Panel 2 17B676 Outside Rear View Mirror Control 3 14028 Door Lock Switch 4 55928-S55 Screw (5 Req'd) 5 14529 Window Regulator Control Switch 6 23942 Front Door Trim Panel
  1. Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
  1. Remove front door trim panel retaining screw through front door trim panel finish panel opening.
    Trim Panels, Door
    Item Part Number Description 1 20124 Front Door 2 23942 Front Door Trim Panel 3 383356-S100 Nut (2 Req'd Each Side) 4 56903-S58 Screw (2 Req'd Each Side)
  1. Remove interior lamp lens cover.
  1. Remove screw through interior lamp opening.
  1. Slide front door trim panel upward to disengage hooks.
  1. Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
  1. Disconnect window regulator jumper wire (14A630) .
  1. Remove front door trim panel.
  1. To install, reverse Removal procedure.
May 07, 2009 | 1994 Mercury Cougar
Sunroof doesn"t open or close
Section 01-17: Roof Panel, Sliding—Electric 1996 Taurus, Sable Workshop Manual DESCRIPTION AND OPERATION Electric Operation The sliding roof panel (502B98):
  • is available as an option.
  • is electrically operated through the accessory delay relay (controlled by generic electronic module (GEM)).
  • is of self-storing design.
  • requires a specific headliner.
  • utilizes a unique roof console and dome lamp.
  • has an air deflector.
The electrical system operates in the following manner:
  • Two switches control movement of the roof panel.
  • When the SLIDE roof sliding panel switch (15B691) is rocked rearward, the roof sliding outer glass panel (502A82) slides into the storage space between the roof trim panel (51968) and the roof panel, exposing an opening over the front seats.
  • When the SLIDE roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully back in the storage space, the roof sliding outer glass panel moves forward from the storage position.
  • The rear portion of the roof sliding outer glass panel moves upward on two lifter arms near the end of the forward travel, allowing a weather-tight seal when the roof sliding outer glass panel is closed.
  • An AUTO feature allows the SLIDE roof sliding panel switch to be touched momentarily to cause the roof panel to automatically move to the fully open position.
  • When the TILT roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully forward, the rear of the roof sliding outer glass panel pops up to the VENT position.
  • With the roof sliding outer glass panel in the VENT position, rocking the TILT roof sliding panel switch rearward closes the roof sliding outer glass panel.
  • Open power feed fuse.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
  • Damaged roof panel
  • Obstructed roof panel
  • Guide
  • Damaged drive cable(s)
  • Open Power Distribution Box Fuses 1 (40A) or 4 (30A)
Apr 19, 2009 | 1996 Ford Taurus
Samsung SGH-S5230 Cell Phone Logo
16 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
