Question about Raymarine ST4000 GPS Receiver
My st4000 wheel pilot turns on with the boat, rudders center up like normal, but then if I push the AUTO button the power fuse blows
Are you sure that you've got the correct value fuse in? Check that the motor/gearbox assembly will turn; ie, it's not siezed up. Check the wiring to the motor to make sure that there's no short circuit anywhere.
Posted on Nov 18, 2010
Raymarine 4000 + autopilot. I immediately get an RG Fail message when I engage the autopilot on my Catalina 320 Sailboat.
I am not familiar with your particular model autopilot, but I do know that Raymarine autopilots can be fussy. All must have a compatible gps feeding it, of course. All must have a rudder angle indicator if your auto pilot connects to the wheel or rudder instead of directly to the tiller.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Aug 25, 2017 | Raymarine Boating
Steering gear
Hi Alfred.
Your answer will depend on the fishing boat.
For really small boats, with an outboard motor on the back, the motor will be on a pivot joint, and have a handle in front. You point the running motor side to side to steer the boat.
Larger boats with outboards will have a steering wheel with a mechanical linkage to an outboard motor or motors that will pivot them side to side to steer.
Larger fishing boats, especially commercial boats, will have an inboard engine and prop shaft, a fixed external propellor or propellors, and a rudder that is connected with a mechanical linkage to the steering wheel or ships-wheel to move the rudder side to side and steer the boat by deflecting how the water flows by when under way.
Hoping this helps.
D
Dec 16, 2015 | Boating
MY SIMRAD AUTO pilot is telling me rudder error what is the problem is it the linear feed back cylinder
Has it ever worked?
What has changed?
Is it the a "pole/linear" or a "rotary" FB unit?
Out of the 5 basic parts of the AP system, the RFB is the most replaced due to the environment (Splash, heat, vibration, mech movemnet).
"Rudder feedback error"
does not see the RFB at all.
check the connections in the J-box first.
you should be able to manually turn your wheel and see the RFB indicator change on the control head.
"rudder responce error"
does not see the RFB move when the AP is given a command.
then check physical connections.
could be loose, could be backward?
Nov 28, 2010 | Simrad Lf3000 Linear Feedback 20188074...
Motor only steers too one side. I have reversed the polarity and it still drives the same side.
what type of pilot?
Is there a rudder reference unit installed? if yes check rudder ref unit.
Does it does this only in auto?
Set standby and check if +10 and -10 pilot is turning in correct direction.If not See manual for installation drws and setup instructions.
Sep 18, 2010 | Raymarine St 4000 Wheel Drive E12093
Auto pilot will not hold course. Wants to go to port as soon as it is turned on
What model autopilot? If it is a Raytheon/Raymarine try switching the motor leads to see if that works.
May 16, 2010 | Boating
My st4000 mkII shuts off from auto mode whhen i engage the clutch lever and the wheel turns for a second. the screen goes blank and just displays "st4000" . voltage is fine and all wires are connected....
CHECK THE POWER SUPPLY WIRING ,If it worked before ,could be corrosion or lose wire connection,or terminal bad crimped,or terminal loose inserted.
If it is new installation ,power wires could be undersized,or battery discharged .
Normally autopilot shuts off from auto and restarts when power supply voltage drops under the reset voltage ,when the wheel turns ,the motor current increase and the power voltage drops when the power supply wires are not OK.
Apr 06, 2010 | Raymarine St 4000 Wheel Drive E12093
Linear rudder refernce Furuno 500 auto pilot will not pass test?
light on board is probably normal no, this is an inductive pickup, can not test with ohmeter, sorry. Test with display, observing rudder angle display. Do rudder setup repeatedly until it works, it is a little fussy for placement and clearance but patience and the correct "bracketry" will make this pilot perform great.
Apr 06, 2009 | Furuno Navpilot 500 Navigational Autopilot...
RayMarine wheel 4000
You would need to supply more info to pin point problem. 1) Do you have hydaulic steering?If so do you have a rudder feed back sensor. 2) Is this a new install or did the pilot work properly before 3) Do you have a smart pilot course computer in the system or is the wheel drive run straight from the head unit. 4)What was the deveation reading on your auto pilot compass when it was swang. 5)Was the pilot comissioned by a qualified person. I know there is a lot of questions here but there could be many things that are causing the S.Once the above questions are resolved I should be able to narrow it down to one or two things. Regards Robert
Aug 13, 2008 | Raymarine St 4000 Wheel Drive E12093
Sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Jul 14, 2008 | Raymarine A65 Combo GPS...
Raymarine ST4000 GPS Receiver Logo
130 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Goldi Kunal
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
